I tried to simulate a basic powder spectrum of Cu2+. When simulating it with pepper (script Copper_pepper.m) and the experimental g values, I get a very good simulation with g=[2.06 2.06 2.34]. When optimizing the g values with esfit (script Copper_esfit.m), I also get a very good simulation but with significantly different g values : g=[2.0952 2.0952 2.3809].
Clearly the set of g values given by esfit is wrong. What could be the reason ?
Thanks for your help
all the best
Laurent
discrepancy between pepper and esfit simulation
- BE3_P2M1_G30_chp_large-bl.DTA
- experimental spectrum
- (32 KiB) Downloaded 292 times
- Copper_pepper.m
- Matlab script for simulation with pepper and experimental g values
- (337 Bytes) Downloaded 292 times
- Copper_esfit.m
- Matlab script for simulation with esfit
- (282 Bytes) Downloaded 305 times
- EasySpin Guru
Re: discrepancy between pepper and esfit simulation
You'll also need to include the .dsc file.
Here is the DSC file.
I could not upload it with my previous post because the uploading was limited to 3 files.
- BE3_P2M1_G30_chp_large-bl.DSC
- (4.19 KiB) Downloaded 275 times
- EasySpin Guru
Your simulation magnetic field range doesn't match with your experimental range. Usually its best to pull those from the actual experimental parameters so you don't run into errors.
clear;
[B_exp,spc_exp,Params]=eprload('BE3_P2M1_G30_chp_large-bl.DTA');
B_exp = B_exp/10;
Sys.S = 1/2;
Sys.g = [2.06 2.06 2.343];
Sys.lwpp = [0 6.16];
Sys.gStrain = [0.0 0.0 0.082];
Exp.mwFreq = Params.MWFQ/10^9;
Exp.Range = [min(B_exp) max(B_exp)];
Exp.nPoints = length(B_exp);
[B_calc,spc_calc] = pepper(Sys,Exp);
spc_calc = rescale(spc_calc,spc_exp,'lsq');
plot(B_exp,spc_exp,B_calc,spc_calc);
xlim([150 450])
Vary.g=[0.05 0.05 0.05];
esfit('pepper',spc_exp,Sys,Vary,Exp);
Thank you very much for your help and the improved script. Indeed in the DSC file, I confused the sweep width with the maximum field, therefore the wrong field range!
all the best
all the best
