discrepancy between pepper and esfit simulation
binet
Post by binet »
I tried to simulate a basic powder spectrum of Cu2+. When simulating it with pepper (script Copper_pepper.m) and the experimental g values, I get a very good simulation with g=[2.06 2.06 2.34]. When optimizing the g values with esfit (script Copper_esfit.m), I also get a very good simulation but with significantly different g values : g=[2.0952 2.0952 2.3809].
Clearly the set of g values given by esfit is wrong. What could be the reason ?
Thanks for your help
all the best
Laurent
BE3_P2M1_G30_chp_large-bl.DTA
experimental spectrum
(32 KiB) Downloaded 784 times
Copper_pepper.m
Matlab script for simulation with pepper and experimental g values
(337 Bytes) Downloaded 741 times
Copper_esfit.m
Matlab script for simulation with esfit
(282 Bytes) Downloaded 735 times
Re: discrepancy between pepper and esfit simulation
You'll also need to include the .dsc file.
binet
Post by binet »
Here is the DSC file.
I could not upload it with my previous post because the uploading was limited to 3 files.
BE3_P2M1_G30_chp_large-bl.DSC
(4.19 KiB) Downloaded 747 times
Your simulation magnetic field range doesn't match with your experimental range. Usually its best to pull those from the actual experimental parameters so you don't run into errors.
clear;
[B_exp,spc_exp,Params]=eprload('BE3_P2M1_G30_chp_large-bl.DTA');
B_exp = B_exp/10;
Sys.g = [2.06 2.06 2.343];
Sys.lwpp = [0 6.16];
Sys.gStrain = [0.0 0.0 0.082];
Exp.mwFreq = Params.MWFQ/10^9;
Exp.Range = [min(B_exp) max(B_exp)];
Exp.nPoints = length(B_exp);
[B_calc,spc_calc] = pepper(Sys,Exp);
spc_calc = rescale(spc_calc,spc_exp,'lsq');
plot(B_exp,spc_exp,B_calc,spc_calc);
xlim([150 450])
Vary.g=[0.05 0.05 0.05];
esfit('pepper',spc_exp,Sys,Vary,Exp);
binet
Post by binet »
Thank you very much for your help and the improved script. Indeed in the DSC file, I confused the sweep width with the maximum field, therefore the wrong field range!
all the best
