the spectra I want to simulate is changed in the screen
htuner
Post by htuner »
I wish you a peaceful and joyful holiday season.
I am trying to simulate the following spectrum
Ekran görüntüsü 2024-12-22 160825.png (17.61 KiB) Viewed 24777 times
However, when I run the code the simulation screen looks like this;
Ekran görüntüsü 2024-12-22 161105.png (42.52 KiB) Viewed 24777 times
The magnetic fields(G) and the Intesities are as follows;
3362.05241 9.06E-7
3365.6947 0.00249
3369.35504 0.00572
3373.0951 0.01224
3375.50432 -0.00254
3377.83083 -0.02073
3381.43552 -0.01979
3385.24626 -0.01035
3388.46742 -0.02522
3391.94577 -0.02949
3395.35192 -0.03673
3399.01677 -0.03331
3402.70419 -0.02896
3405.92409 -0.01033
3408.93192 -0.00439
3411.5307 -0.01412
3414.15396 -0.02679
3417.17709 -0.01626
3419.65403 -0.00141
3422.78416 0.00681
3426.14519 -0.00229
3429.74236 -0.00166
3433.60725 0.01
3437.28564 0.01398
3441.07683 0.02261
3444.90562 0.03278
3447.87811 0.04122
3450.25658 0.05777
3451.57167 0.07267
3453.42382 0.08861
3455.58784 0.10399
3458.57577 0.11977
3462.29888 0.1323
3465.42628 0.14712
3467.67003 0.16387
3469.34457 0.18112
3471.05455 0.19983
3472.52071 0.21616
3474.3364 0.23476
3475.82393 0.25223
3477.64603 0.26828
3480.63617 0.28415
3484.24537 0.28527
3486.49732 0.27072
3487.42124 0.25288
3487.98467 0.23808
3488.55545 0.22134
3489.00353 0.20625
3489.42404 0.19003
3489.83213 0.1733
3490.26505 0.15759
3490.55182 0.14257
3490.95165 0.12549
3491.35974 0.10876
3491.69339 0.08896
3491.72464 0.07235
3491.97307 0.05351
3492.05461 0.03674
3492.33468 0.01665
3492.37061 -0.00258
3492.54267 -0.02367
3492.44432 -0.04562
3492.43421 -0.06393
3492.51786 -0.08509
3492.56694 -0.10454
3492.56253 -0.12351
3492.48752 -0.14002
3492.22061 -0.15639
3492.50627 -0.17415
3492.34827 -0.19274
3492.47557 -0.20986
3492.22649 -0.22907
3492.27134 -0.24825
3492.40572 -0.26866
3492.28568 -0.28524
3492.58128 -0.30393
3492.43375 -0.32343
3492.59231 -0.34374
3492.74948 -0.3641
3492.83054 -0.38626
3492.99599 -0.4036
3493.06106 -0.42316
3493.26925 -0.43998
3493.63067 -0.4572
3495.14227 -0.4797
3498.31669 -0.47017
3499.734 -0.45336
3501.26528 -0.43364
3502.45465 -0.41593
3503.28279 -0.3997
3504.56568 -0.38037
3505.51492 -0.36138
3506.60547 -0.34327
3507.94488 -0.32162
3508.88172 -0.30314
3510.10423 -0.28439
3511.33562 -0.26239
3512.28574 -0.24336
3513.43558 -0.22281
3514.82325 -0.19917
3515.84694 -0.17711
3517.1381 -0.15744
3518.33183 -0.13732
3519.16824 -0.12074
3520.42011 -0.1027
3521.83466 -0.08466
3523.23424 -0.06915
3524.90807 -0.05193
3527.69912 -0.03755
3530.93687 -0.02489
3533.62259 -0.00815
3536.14838 0.00872
3539.35651 0.02016
3542.95974 0.02775
3546.19009 0.04681
3547.91859 0.06245
3549.55492 0.08005
3551.03014 0.09867
3552.43807 0.11644
3553.44618 0.13115
3554.82434 0.14768
3556.24283 0.16397
3557.954 0.18273
3560.90443 0.19697
3564.51513 0.19816
3568.24616 0.2043
3571.70429 0.21262
3574.22548 0.2293
3575.79445 0.24699
3577.16764 0.26333
3578.57944 0.28125
3579.93333 0.29679
3581.46025 0.31275
3583.05656 0.32934
3584.54096 0.34444
3586.22023 0.36131
3588.0881 0.3779
3590.9898 0.39013
3593.15374 0.37866
3594.043 0.36297
3594.51176 0.3474
3595.09909 0.33134
3595.45756 0.31256
3595.52492 0.29521
3595.623 0.27912
3595.78514 0.25896
3595.79029 0.2368
3595.67677 0.22094
3595.42392 0.20515
3595.54671 0.18426
3595.33899 0.16407
3595.22097 0.14578
3595.26178 0.13002
3594.77206 0.11386
3594.85093 0.09966
3594.74614 0.08192
3594.5625 0.06227
3594.2376 0.03699
3594.08634 0.0135
3593.78932 -0.00717
3593.616 -0.02889
3593.45512 -0.05316
3593.15402 -0.07362
3593.00307 -0.09634
3592.77066 -0.11934
3592.56062 -0.14103
3592.37753 -0.16334
3592.16796 -0.18674
3591.87347 -0.20693
3591.74884 -0.22952
3591.49516 -0.25339
3591.40278 -0.27062
3591.04983 -0.28853
3590.93816 -0.30991
3590.73096 -0.3357
3590.47905 -0.36238
3590.33291 -0.38183
3590.25322 -0.39988
3590.09853 -0.41833
3589.90909 -0.43822
3589.89743 -0.46017
3589.63482 -0.48218
3589.57379 -0.50304
3589.58978 -0.51983
3589.67747 -0.53635
3589.58978 -0.55338
3589.86718 -0.57416
3590.64036 -0.59061
3592.05173 -0.59954
3593.99889 -0.57968
3595.16724 -0.56124
3596.36033 -0.53738
3597.30557 -0.51721
3598.07434 -0.49894
3598.71958 -0.4804
3599.93914 -0.45659
3600.80556 -0.43334
3601.72594 -0.41171
3602.61212 -0.38796
3603.9559 -0.35718
3603.38787 -0.37388
3604.80243 -0.33571
3605.65906 -0.31606
3606.6428 -0.29341
3607.5173 -0.26887
3608.74316 -0.24327
3609.53001 -0.22138
3610.54021 -0.20179
3611.08657 -0.18407
3612.21159 -0.16454
3613.54736 -0.1392
3614.83113 -0.11697
3616.19146 -0.09893
3617.97734 -0.08124
3620.0079 -0.06465
3622.06824 -0.04684
3624.08887 -0.03066
3626.06648 -0.01626
3628.05403 -0.00144
3630.23404 0.01459
3632.74604 0.03089
3636.02485 0.04524
3639.7642 0.05844
3643.04911 0.07305
3646.43834 0.08524
3649.94527 0.08215
3653.59959 0.08513
3657.04335 0.07944
3660.46906 0.073
3663.00036 0.05654
3665.71516 0.04765
3669.67179 0.06309
3672.57567 0.06199
3673.91861 0.04487
3674.44992 0.02995
3675.25903 0.01345
3676.04765 -0.00198
3678.48849 -0.01641
3681.96684 -0.02068
3685.58357 -0.01925
3688.97318 -0.02717
3692.43799 -0.032
3696.19158 -0.02492
3699.72859 -0.02677
3703.22499 -0.03029
3706.29393 -0.01117
3708.4949 0.00573
3711.42102 0.01225
3713.92425 0.00135
I tried to save the text data to the DSC file, but the spectra look like the ones on the simulation screen.
What is the problem here? Why did Easyspin not use my data, and did easyspin generate its own, especially the magnetic field?
Thank you.
hasan
Re: the spectra I want to simulate is changed in the screen
The reason is that your magnetic field axis is not linear, and even not monotonic. If you load your two-column data into a MATLAB variable data and then plot(data(:,1),data(:,2), you will get the correct spectrum, but plot(data(:,2) (which assumes a linear axis) will give what you see in esfit.
You can see the non-monotonicity of the field in the second peak of your first plot - when the spectral intensity drops, it actually goes backwards in field, so that there are field values where there are several spectral values.
htuner
Post by htuner »
Thank you Stefan. Now understand.
