Script for mT to g-factor Conversion
Dmytro Kravchuk
Post by Dmytro Kravchuk »
Hello everyone!
I am new to both MatLab and EasySpin. I know that the g-factor for a singular point (mT) can be easily calculated via “eprconvert” if the frequency is known. But I was wondering if there is a script to convert the entire B into g-factor to be used on the x-axis?
I have been working on Magnettech (.XML) and old Bruker instruments (.SPC/.PAR) running variable temp studies. My only option to compare the spectra from each instrument is plotting the data as g-factors in bulk. Any way EasySpin can read parameters, find the experimental frequency, and use it to convert mT to g-factors for the entire dataset?
Thank you!
Re: Script for mT to g-factor Conversion
Something like:
g = 714.477*Exp.mwFreq./B
might do the trick, where B is the magnetic field vector.
Here is a complete example:
mwFreq = 9.5245;  % GHz
B = linspace(300,400,51);  % mT
g = planck*mwFreq*1e9/bmagn./(B*1e-3);
plot(B,g,'o-')
xlabel('magnetic field (mT)')
ylabel('g value')
title(sprintf('%g GHz',mwFreq));
grid on
