I want to define a system which includes an alkali metal atom like 87 Rubidium. You all know that alkali atoms have only one valance electron. So I want to calculate Hamiltonian of the system under magnetic field B (along z-axis)
At that time I must write Hyperfine coupling constant or tensor (A). But I have no idea about that. It does not need to be a precise value because I will make an assumption about Hperfine coupling constant and I will assume it is isotropic. How can I calculate simple Hyperfine coupling constant of an isotope or where can I find Hyperfine coupling constants of isotopes?
Note: There are always 1 electron in my system. Therefore, we can think that Hyperfine interaction Hamiltonian caused only between 1 electron and 1 nuclei&isotope.
The hyperfine constant for rubidium is well known - you'll it by googling "rubidium hyperfine". It's about 1 GHz.
To convert to another Rb isotopes (neglecting any potential isotope effects on the electron distribution), use EasySpin's nucgval: A_87Rb = A_85Rb/nucgval('85Rb')*nucgval('87Rb').
Rb.S = 1/2;
Rb.Nucs = '85Rb';
Rb.A = 1012; % MHz
B = [0 0 0]; % mT
H = ham(Rb,B);
E = eig(H)/1e3 % -> GHz
shows that at zero field, the hyperfine interaction splits the electronic 2S_1/2 ground state of Rb into a lower-lying quintet (F=2) and a higher-lying septet (F=3).
