Does esfit account for ESEEM deadtime?
a.froes
Post by a.froes »
I've been working a 3pESEEM fitting script for a while and I've noticed that when you output the data, there is a time-domain offset between the experimental set, and the simulated set. I assume this is due to deadtime in the experimental spectrum. Does esfit take deadtime into consideration when fitting ESEEM data? Or does this need to be manually input through some set of parameters?
Thanks!
Re: Does esfit account for ESEEM deadtime?
You can specify the deadtime (i.e. intial T value) - see documentation here.
