Fitting mwPhase for multicomponent spectrum?
howie
Post by howie »
Can anyone offer advice on how to fit the microwave phase for multicomponent spectra? I can follow the EasySpin documentation for mwPhase fitting for single component spectra, but when I try to add a second component, the code doesn't work. Is there a way to add a second Sys in the 'mymy' function to make the code work? Thanks in advance!
Sys1.g = 2.01652;
Sys1.lwpp = [0 152.28];
Sys1.S = 1/2;
Sys1.mwPhase = -0.117033;
Sys1.weight = 2.99768;
Vary1.g = 0.2;
Vary1.lwpp = [0 50];
Vary1.weight = 0.2;
Vary1.mwPhase = 20*pi/180;
% carbon
SysC.g = 1.99574;
SysC.lwpp = 12.1384;
SysC.weight = 0.00082928;
VaryC.g = 0.02;
VaryC.lwpp = 5;
VaryC.weight = 0.0005;
esfit('mymy',data{y1:y2,2},{Sys1,SysC},{Vary1,VaryC},Exp);
function y = mymy(Sys,Exp,Opt);
Exp.mwPhase = Sys.mwPhase;
[x,y] = pepper(Sys,Exp,Opt);
Re: Fitting mwPhase for multicomponent spectrum?
You have to take in account that the parameter Sys in custom similation function is cell array in the case of multicomponent fitting. Try to use Exp.mwPhase = Sys{1}.mwPhase;
howie
Post by howie »
Thank you!
