Some newbie in pepper
anubis_by_itself
Post by anubis_by_itself »
Hello :D
I'm using esfit pepper to fit some Mn spectrum.
When I'm using monte-carlo or other global methods it keeps informing me with this:
WARNING: No resonance fields at 9.8 GHz between 310.345 and 398.052 mT.
Check field range and spectrometer frequency.
Warning: Rank deficient, rank = 1, tol = 2.057952e-11.
In rescale
In esfit
In esfit_montecarlo
In esfit
Script in the attachment
Could someone help me to fit this correctly? I just know it is X-band spectrum of Mn ethalone
MnEthalone_take2.m
(650 Bytes) Downloaded 302 times
3Mn_etalon_MX_120_17_10_13.DTA
(16 KiB) Downloaded 372 times
imoseley94
Re: Some newbie in pepper
Post by imoseley94 »
Without the DSC file along with the DTA I am not sure I can confirm your issue. I would try changing the Exp.Range to what ever values you want to use "Exp.Range = [0 500]; % in mT " As you may be having some confusion since you are using a B/10 conversion factor as well. Hope you figure it out.
anubis_by_itself
Here it is. Could you please help me out with it?
3Mn_etalon_MX_120_17_10_13.DSC
(3.15 KiB) Downloaded 326 times
The specific error you've encountered likely comes from the range you've provided with vary being overly large(specifically vary.g). As a result, some of the parameter sets generated from monte-carlo end up being out of the field range you've specified.
In general though, I would say its good practice to adjust your initial parameters to get a reasonably good fit, this also gives you a better idea on the range to vary, then use esfit either with simplex or or levmar to nail down the fit. So do something like this:
clear, clc, clf
[B,spc,par] = eprload('3Mn_etalon_MX_120_17_10_13.DTA');
B = B/10;
spc=spc/max(spc);
plot(B,spc);
Mn.S = 1/2;            %MHz
Mn.Nucs = '55Mn';
Mn.g = 2;
Mn.lwpp = 0.5;
Mn.A = 240; %MHz Exp.mwFreq = par.MWFQ/10^9; Exp.Range = [min(B) max(B)]; Exp.ModAmp = 0.5; %mT Exp.nPoints = length(B); [b1,sim] = pepper(Mn,Exp); sim = sim/max(sim); plot(B,spc,b1,sim) %% Vary.g = 0.5; Vary.lwpp = 0.3; Vary.A = 50; esfit(@pepper,spc,Mn,Vary,Exp);
I personally have not had very good luck using any of the minimization methods aside from simplex or levmar.
