Orcaview; display only average A values
Grahamhaug
Post by Grahamhaug »
I am hoping to make a simple change to the OrcaView code to display only the average hyperfine values instead of the x, y, z, average currently displayed. I've successfully updated the font size to be more readable in my Excel spreadsheets but seeing only the average A values is my current priority. This is for ease of determining proton couplings compared to experimental/literature values/across many geometries optimized using different DFT XC functionals.
I believe this is the relevant section of the OrcaView code (I am a matlab beginner):
% Hyperfine
if hyperfineDisplay || plotHFframe
A = thisdata.hfc{iAtom};
if isempty(A), continue; end
[V,E] = eig(A); A = diag(E);
[~,idx] = sort(abs(A)); A = A(idx); V = V(:,idx);
maxA = max(abs(A));
aboveThreshold = maxA > 1;
if hyperfineDisplay && aboveThreshold && ~plotHFframe
str = sprintf(' %0.2f, %0.2f, %0.2f (%0.2f)',A, mean(A));
h = text(xyz(iAtom,1),xyz(iAtom,2),xyz(iAtom,3),str,'Parent',hDisplay);
set(h,'Fontsize',16,'VerticalAl','bottom','Color',[0 0.6 0]);
if plotHFframe
hfarrowLength=0.4;
V = hfarrowLength*V;
dir1 = V(:,1);
dir2 = V(:,2);
dir3 = V(:,3);
Origin = thisdata.xyz(iAtom,:);
% principal directions
h = [];
h(1) = line(Origin(1)+[-1 1]*dir1(1),Origin(2)+[-1 1]*dir1(2),Origin(3)+[-1 1]*dir1(3),'Color','r','Parent',hDisplay);
h(2) = line(Origin(1)+[-1 1]*dir2(1),Origin(2)+[-1 1]*dir2(2),Origin(3)+[-1 1]*dir2(3),'Color',[0 0.5 0],'Parent',hDisplay);
h(3) = line(Origin(1)+[-1 1]*dir3(1),Origin(2)+[-1 1]*dir3(2),Origin(3)+[-1 1]*dir3(3),'Color','b','Parent',hDisplay);
set(h,'LineWidth',0.5);
% principal values
format = ' %+0.2f';
h(1) = text(Origin(1)+dir1(1),Origin(2)+dir1(2),Origin(3)+dir1(3),sprintf(format,A(1)),'Color','r','Parent',hDisplay);
h(2) = text(Origin(1)+dir2(1),Origin(2)+dir2(2),Origin(3)+dir2(3),sprintf(format,A(2)),'Color',[0 0.5 0],'Parent',hDisplay);
h(3) = text(Origin(1)+dir3(1),Origin(2)+dir3(2),Origin(3)+dir3(3),sprintf(format,A(3)),'Color','b','Parent',hDisplay);
set(h,'FontSize',16);
% ellipsoids
N = 11;
r = abs(A);
r = r/max(r);
r = max(r,0.1)*hfarrowLength*1.8;
theta = linspace(0,pi,N);
phi = linspace(0,2*pi,2*N);
[theta,phi] = meshgrid(theta,phi);
xhf = r(1)*cos(phi).*sin(theta);
yhf = r(2)*sin(phi).*sin(theta);
zhf = r(3)*cos(theta);
vecs = V*[xhf(:) yhf(:) zhf(:)].';
xhf = reshape(vecs(1,:),2*N,[]);
yhf = reshape(vecs(2,:),2*N,[]);
zhf = reshape(vecs(3,:),2*N,[]);
c = sqrt(xhf.^2+yhf.^2+zhf.^2);
hs = surface(xhf+Origin(1),yhf+Origin(2),zhf+Origin(3),c,'Parent',hDisplay);
set(hs,'FaceColor','interp','Clipping','off');
I thought the modification would be as simple as changing the following line:
To the new version:
str = sprintf('(%0.2f)',A, mean(A));
However now when I run the code I get a mismash of X,Y,Z over top of one another, some compilation error, or the need to have ellipsoids active (I am looking to have the only value on the image be the average A value over each H atom.
Thank you for any tips or advice,
GCH
Re: Orcaview; display only average A values
str = sprintf('(%0.2f)',mean(A));
should do it.
