Converting from Matlab file to Bruker spectrometers file
earthcookie
Post by earthcookie »
Hello!
I was struggling with converting files from .mat to .DTA/.DSC. The reason I wish to convert this file is because I wish to do least-square fitting with the external data I have (which is in text file). When I tried to convert from Text file to Bruker spectrometers file, the workshop produced empty bracket data. When I tried to convert from Excel file to Bruker spectrometers file, some of the numerical values came out with NaN in cells.
At this point I do not know what to do anymore. Please let me know!
joscha_nehrkorn
Re: Converting from Matlab file to Bruker spectrometers file
Post by joscha_nehrkorn »
If you want to fit your data using EasySpin, there is no need to convert it to the Bruker file format. Once you have it as an array in Matlab you are good to go. Anyhow, what did you try?
You can save data from Matlab to Bruker DSC/DTA files using eprsave - see http://easyspin.org/easyspin/documentat ... xport.html
