User-friendly GUI for metal complexes sim & fit: Simultispin
Florian
Post by Florian »
:arrow: Last release here:
For Easyspin 5
For Easyspin 6
This is a GUI to help users simulating and fitting with Easyspin for cw-EPR spectra.
It is a fork from Simlabel by Emilien Etienne. While Simlabel aims slow motion and spin labelling, Simultispin is particularly dedicated to metal complexes in frozen solution (pepper). Fast motion mode (Garlic) is also available.
You will be able to load experimental spectra / save, load and compare simulated spectra / run fitting process and so on... with no coding, simply by clicking on buttons and moving sliders!
The main features are the following:
  • Selection of the electronic spin S value, not only 1/2
  • Choice of the experimental temperature
  • Choice between perpendicular or parallel modulating magnetic field (for integer high spin like Mn(III) S=2)
  • Setting of Zero Field Splitting parameters D and E for S>1/2
  • Setting of Strains
  • Settings of g-value (iso / axial / rhombic), linewidth, hyperfin coupling...
  • Add several components parameters and relative weight for each of them
To install it (of course Easyspin has to be previously installed):
  • Download and unzip the zip folder on your computer
  • In Matlab, go to "set path" -> "add with subfolders" -> select the folder where you have unzipped the files -> save, close
  • in Matlab command window, type "simultispin" -> Lets go!
For those like me who prefer dark theme on their screen, you have the choice, white or darker!
I would be glad for your feedbacks, positive as negative!
simultispin_darktheme.zip
(1.49 MiB) Downloaded 3698 times
simultispin_whitetheme.zip
(1.49 MiB) Downloaded 3739 times
Florian
Re: User-friendly GUI for metal complexes sim & fit: Simulti
Post by Florian »
Here is an update of Simultispin to download.
Changes implemented:
- Rearragement of buttons and spectra lists (shorter but broader) of the main panel
- small resize of the component windows
- Experimental temperature and perpendicular / parallel mode you have chosen for simulation are now automatically saved and reloaded when you handle simulated spectra
Have a good sim!
(1.49 MiB) Downloaded 3967 times
(1.49 MiB) Downloaded 3933 times
Alexander Shames
Post by Alexander Shames »
Dear Florian:
I am trying to use your perfect Simultispin software for some simulations of Mn(III)Mn(IV) complexes. Unfortunately, after launching the program (Matlab R2014b) and trying to simmulate the spectrum, immediately after clicking on "+" I get the following error report
Error using matlab.ui.Figure/horzcat
Cannot convert double value NaN to a handle
Error in simultispin/addcomponent (line 2123)
place=find([componenth.hfig]==hfig); %indice de la composante consideree dans la structure des handles componenth
Each attempt to enter values (g or A into the corresponding windows) causes the same erroros (just line number change)
Error using matlab.ui.container.Panel/horzcat
Error in simultispin/cllbckeditg (line 3973)
place=find([componenth.hpanelg]==hpanel); %indice considere dans la structure des handles componenth
Please, advise what can I do to move further. I need these simulations ASAP. Thank you in advnce, sincerely
Alex
Alexander Shames
In continuation to my previous message.
OS Windows 10 Home 64-bit operating system, 64-bit operating processor
MATLAB R2014b
I found that launching SimLabel (ver 2017) causes the same problems reporting the same errors.
Maybe it will help is answering my question.
Alex
Alexander Shames
Hi, Florian!
As I wrote you thу same problem was on using SimLabel. Emilien found the problem and helped me a lot. Here is his solution:
search the following lines in the simlabel.m
CODE: SELECT ALL
if versionyear>2014
hinit=gobjects; %handle=structure
else
hinit=NaN; %handle=double
and replace the first line by
CODE: SELECT ALL
if versionyear>=2014
I have changed the corresponding lines (in both SimLabel and simultispin) and they are working!
Thank you again for the great soft.
Alex
Florian
Post by Florian »
Hello Alex,
Thank you for your message thread and glad to read that your bug is fixed. (and thanks to Emilien for the summer watch!)
Florian
Florian
Re: User-friendly GUI for metal complexes sim & fit: Simultispin
Post by Florian »
Please find here a new release of Simultispin Gui for the simulation and fitting of powder / frozen solution / metal complex spectra.
What's new:
- A baseline correction tool for the experimental spectra. You can adjust the baseline fit and then the corrected spectrum can be saved in Bruker format for further analysis (the frequency is automatically recorded).
- The component window has been a bit reorganized and resized, for example the S values are now in a popup menu with fraction format.
- Update of the user manual.
- Some bugs fixed.
This version is compatible with the previous ones.
Have a good sim!
Florian
simultispin_sept2019_darktheme.zip
(1.55 MiB) Downloaded 3815 times
simultispin_sept2019_whitetheme.zip
(1.55 MiB) Downloaded 3697 times
Andrea
Post by Andrea »
Hi Florian,
first of all, thanks for sharing your work with us.
I as having troubles with your previous version but your new upload fixed most of them. The only issue that I still have is, after adding all of my parameters for the simulation, to do use esfit function. When I click esfit, the little window with all the parameters that I want to change pops up but then I get an error message on MatLab.
Undefined function or variable 'Thank".
Error in simultispin/ok4esfit (line 6078)
         Thank you so much for your help!
I use MatLab R2019a
Do you have any suggestions how to fix the bug?
Thank you,
Andrea
Florian
Post by Florian »
Hello Andrea,
At least, this bug is polite :-)
Maybe you wrote some words in the code of simultispin by mistake instead of your email app for example. That could happen if you have opened the simultispin.m file in Matlab.
What I suggest to you is to delete simultispin from your computer and then download it and run it again. Let me know how it is.
To install simultispin, it is not necessary to open the .m file. In Matlab, you just need to "set its folder path" and then type "simultispin" in the command window... as you did it to install and run easyspin!
Florian
Andrea
Post by Andrea »
Ha, yes, it was very polite and easy to fix.
