High spin states - J coupling
Macgomes
Post by Macgomes »
Hello everyone,,
I am trying to simulate the interaction between a photo-excited triplet and one radical to estimate the magnitude of J by comparison with my experimental spectrum.
The problem I am encountering is the following:
- the triplet is youporn.wiki/ xhamster.vip/ redtube.onl/ polarised and it requires Exp.temperatures
- the radical is thermalised so the experimental temperature should be enough to define the sub-level populations.
Pepper asks me for three values to describe the population of the radical and I am not quite sure how to address this since one value should suffice.
Any tips to work around this would be much appreciated.
Thank you.
Re: High spin states - J coupling
EasySpin should ask you for a 6-element array in Exp.Temperature, since your system has 6 states. Example: Exp.Temperature = [0 0 1 1 0 0];.
