I have a problem for many systems that containing "A" values
tui1994
Post by tui1994 »
I have found that the code was error after I write a code for 6 systems by using pepper function. In each system contains hyperfine coupling constant tensor by dependence to nucleus of hydrogen. Then I run the code, there is error code that I gave
Error using pepper
The system contains A and/or Q fields, but no nucleus is specified!
Error in pepper
Error in glucose_all_C (line 130)
pepper({SysG2,SysG3,SysG4,SysG5,SysG6},Exp);
If anyone have some suggestions or solutions, please reply me. Thank you
Re: I have a problem for many systems that containing "A" va
It looks like you forgot (or misspelled) the Sys.Nucs field.
