HYSCORE Simulation
willy40
HYSCORE Simulation
Post by willy40 »
Can someone give me a clue on how to simulate the 2D hyscore data?
I know how to import time domain or Freq.domain( FFT of the data) and writing a code to create a simulation but I don't seem to know
how to use 'esfit' as the data is a 2D array?
Re: HYSCORE Simulation
You can't really fit HYSCORE data using esfit, nor should you try.
You can of course simulate the data using saffron but then you'll need to qualitatively compare the arc/peak positions by hand.
willy40
Post by willy40 »
Thanks Matt!
It's a bit challenging if one has to change parameters and qualitatively compare how similar things are
I appreciate your response !
