Esfit- pepper discrepancies
Jurec IRB
Post by Jurec IRB »
Hey, sorry for bothering you. I'm PhD student for Zagreb, Croatia (IRB) and I am using the latest version of easyspin (5.2.11.).
I have a problem and I hope you will give me some kind of advice how to fix it.
I have experimental data that I fitted a couple of months ago using esfit in easyspin. I've got pretty good match with experiment but when I use that data (from esfit that match the experiment) with pepper I am getting some kind of discrepancies.
Basically, I am using the same values of g, A, AFrame, weight and lwpp, same experimental frequency, range and number of points, and I get pretty good match with experiment using this data with esfit. But when I try to plot this with pepper I am getting different picture.
What am I doing wrong?
clear, clf
[B,spc] =textread('/Users/Jurica/Desktop/TREHALOZA/xband/01250315bl.txt');
B=B/10.; %militesle!
Sys.S = 1/2;
Exp.mwFreq =9.6415;
Exp.Range = [339.23 349.23];
Exp.Harmonic = 1;
Exp.nPoints=1024;
Sys1.g = [2.00617 2.00447 2.00221];
Sys1.Nucs = '1H,1H,1H';
Sys1.A = [59.77 72.92 67.72; 9.33 11.36 12.0757; 33.8556 -6.094 5.26];
Sys1.AFrame = [188.17 89.95 97.30; -62.85 -7.53 -109.76; 172.15 -25.08 73.23]*pi/180;
Sys1.lwpp = [1.64286];
Sys1.weight = 1.225;
Vary1.lwpp = [0.00001];
Sys2.g = [2.00694 2.00388 2.00232];
Sys2.Nucs = '1H,1H,1H';
Sys2.A =[34.534 40.20 -3.102; 3.925 -5.2213 11.337; 16.077 12.74 16.65];
Sys2.AFrame = [90.41 -112.83 89.84 ; 89.85 111.22 0.68; -6.45 90.95 -9.20]*pi/180;
Sys2.lwpp = [0.533639];
Sys2.weight = 1.40205;
Vary2.lwpp = [0.00001];
Sys3.g = [2.00586 2.00508 2.00211];
Sys3.Nucs = '1H,1H,1H';
Sys3.A =[67.81 51.7389 12.743; 11.96 8.9889 0.11; 17.32 -17.4202 35.2535];
Sys3.AFrame = [276.27 81.36 91.91; 15.69 64.92 39.79; 23.03 74.67 -6.97]*pi/180;
Sys3.lwpp = [1.88387];
Sys3.weight = 0.32304;
Vary3.lwpp = [0.00001];
%FIRST
Opt = struct('Verbosity',1);
Opt.nKnots = 91;       % increments, no interpolation
SimOpt.Method = 'perturb';
FitOpt.Method = 'simplex int';
esfit('pepper',spc,{Sys1,Sys2,Sys3},{Vary1,Vary2,Vary3},Exp,SimOpt,FitOpt);
%SECOND
[x,y1]=pepper(Sys1,Exp);
[x,y2]=pepper(Sys2,Exp);
[x,y3]=pepper(Sys3,Exp);
[x,y4]=pepper({Sys1,Sys2,Sys3},Exp);
E = plot(B,(spc/max(spc)),'r');
hold on;
S1 = plot(x,(y4/max(y4)),'b');
title(sprintf('glass additonally heated at 90C, %g GHz',Exp.mwFreq));
xlabel ('magnetic field [mT]');
legend ('exp','sum');
Edit: Notice how green line follows the black dots in 1st picture but in second one the blue line doesn't follow the red experimental data.
Shouldn't the green line (in 1st) and blue line (in 2nd) be the same because they are plotted from same parameters?
And excuse my abuse of english language. English is my second language.
Re: Esfit- pepper discrepancies
It looks like you are using 'perturb' for the fitting, but not for the simulation.
