esfit error line 130 using custom function
dgagnon
Post by dgagnon »
I wrote a custom function that outputs a vector of residuals from experimental - simulated for a dozen or so spectra. I'm trying to use esfit to minimize this vector from my function, but keep getting an error.
Specifically:
Error using ~=
Too many input arguments.
Error in /home/derek/Documents/MATLAB/easyspin/easyspin/esfit.p>esfit (line 130)
Output from function is [x,y] = myfunction(Sys,Exps,Opt)
Providing esfit('myfunction',thegoal,Sys,Vary,Exps,Opt) where 'thegoal' is a vector of zeros of equal length and dimensions as y.
Any help with what is causing the error at line 130 of esfit would be greatly appreciated. I can attach a test data set, script, and the function if helpful.
Re: esfit error line 130 using custom function
Are you using an array of experiments structures? The line in esfit that causes the error is
  if Exp.nPoints~=numel(ExpSpec)
If you use an array of structures in Exp, this will give the error you observe.
dgagnon
Post by dgagnon »
You are correct.
So the correct way to do this is to make the parameter(s) I want to vary an array instead of having an array of structures, i.e. do Exp.Field = [350, 351, 352, 353...]. Then per iteration of my custom function create a structure input that salt will be happy with, i.e. NewExp.Field = Exp.Field(i)?
EDIT: So implementing that got me one line further.
Error using esfit (line 131)
Exp.nPoints is 1024, but the spectral data vector is 1 long.
I think I know what to do from here, though. Will post a reply if I get stuck again. Thank you for the help!
