Syntax of Sys.eeD
AndyB
Syntax of Sys.eeD
Post by AndyB »
I try ro do a simulation where I want to include dipolar coupling between two identical spins in the solid state, but I do not quite get the correct syntax for that.
I tried to run the example file eespins from the easyspin examples but I received the following error message:
Sys.ee field is missing in spin system structure!
Error in pepper
Error in eespins (line 16)
pepper(Sys,Exp);
So, whats missing?
Re: Syntax of Sys.eeD
Which EasySpin version are you using? This feature was introduced in EasySpin 5.
AndyB
Post by AndyB »
I was using 5.0.17, but I have updated it now to 5.1.5, and it is working now. Thank you for your help.
