Chili for non-nitroxide systems
wlinde
Post by wlinde »
At the moment, I am simply playing with chili in order to simulate slow motion dynamics of iron-catechol complexes. I have a fairly naive question, centered on the following code:
Sys = struct('g',[2.24 2.24 1.92],'Nucs','56Fe','A',[20,20,85]);
Sys.tcorr = 5e-10;
Exp = struct('mwFreq',4.65,'Range',[20,620],'nPoints',5e3);
chili(Sys,Exp);
Ignoring, for a moment, the fact that the numbers are not correct (I am interested in fitting them later), my question is: what am I simulating, exactly? Is it neutral Fe, Fe 2+ or Fe 3+? Is it in a high or low spin state?
Thanks for your clarification
Re: Chili for non-nitroxide systems
In this case you'd be simulating an S=1/2 iron system. The specific oxidation state of the iron is somewhat irrelevant to the simulation, only the number of unpaired/interacting electrons.
wlinde
Post by wlinde »
Great! Thank you.
How do I control the number of paired/unpaired electrons for the purpose of the simulation. I had trouble finding information about this in the documentation. Suppose, for example, that I was interested in simulation of S=5/2 iron. How could I do this?
joscha_nehrkorn
Post by joscha_nehrkorn »
Sys.S =5/2;
I am not completely sure, but I guess it is one of the first lines of the documentation about the spin system. (Spin 1/2 is a default value)
wlinde
Post by wlinde »
Thank you. I tried that, but there appears to be no difference associated with a change in spin. I am running the following code:
close all
figure(1)
Sys.tcorr = 5e-9;
Sys.S=5/2;
chili(Sys,Exp);
figure(2)
Sys2 = struct('g',[2.24 2.24 1.92],'Nucs','56Fe','A',[20,20,85]);
Sys2.tcorr = 5e-9;
Exp2 = struct('mwFreq',4.65,'Range',[20,620],'nPoints',5e3);
chili(Sys2,Exp2);
It is clear that the spectra are identical for any timescale, but the chili literature makes it seem like high spin counts should still be supported. For instance, it says
With this setting, EasySpin will include the relevant polarization factors resulting from a thermal equilibrium population of the energy levels. For S=1/2 systems, it is not necessary to include the temperature. However, it is important in high-spin systems with large zero-field splittings, and in coupled spin systems with exchange couplings.
Does anyone have any ideas? I'm genuinely unsure what is going wrong.
wlinde
Post by wlinde »
close all
figure(1)
Sys.tcorr = 5e-9;
Sys.S=5/2;
chili(Sys,Exp);
figure(2)
Sys2.tcorr = 5e-9;
chili(Sys2,Exp2);
joscha_nehrkorn
Don't panic! Nothing is wrong. Check solid state spectra without hyperfine interaction for the two cases. They will and they should be identical. Look at the quote from the documentation you posted: It is about zero-field splitting. This is absent in your code, therefore there is no difference. You can add it as
Sys.D = 50000; %MHz
This will change your spectrum strongly.
wlinde
Post by wlinde »
Ah, great. Thank you very much!
