Issue with levelsplot with Matlab R2016a
When using levelsplot with ES 5.0.20 I get two different behaviours depending on the version of Matlab I use, for the same piece of code:
I invoke levelsplot in a rather straightforward manner: I previously define my Sys structure and the experimental details (among which the orientation cori and frequency Exp.mwFreq, and then I just instruct:
Ori=cori; FieldRange=[0 1500]; Freq=Exp.mwFreq; nPoints=10000; levelsplot(Sys1,Ori,FieldRange,Freq,nPoints);
The two behaviours I get are:
Matlab R2015a
I get a warning:
Warning: Struct field assignment overwrites a value with class "double". See MATLAB R14SP2 Release Notes, Assigning Nonstructure Variables As Structures Displays Warning, for
details.
> In levelsplot (line 63)
In full_sim_single_crystal_isosceles_AE (line 64)
However, the calculation goes on and the plot completes.
Matlab R2016a
I get an error:
Field assignment to a non-structure array object.
Error in levelsplot
Error in full_sim_single_crystal_isosceles_AE (line 64)
Ori=cori; FieldRange=[0 1500]; Freq=Exp.mwFreq; nPoints=10000; levelsplot(Sys1,Ori,FieldRange,Freq,nPoints); %For
levelsplot
The calculation stops.
The code has been uploaded from one computer to another without any changes, so I guess there is an issue with the new version of Matlab.
Re: Issue with levelsplot with Matlab R2016a
The last input argument to levelsplot should be a structure:
Opt.nPoints=10000;
Thanks for pointing this out!
Using:
Par.nPoints = 10000;
and invoking levelsplot as
levelsplot(Sys1,Ori,FieldRange,Freq,Par);
did the trick.
The different behaviour between the two Matlab versions gave me the false impression it was a bug.
I see where the confusion came from. In the next version, we will include a proper error message.
