esfit selected range
Mantas_Sim
Post by Mantas_Sim »
Hello!
I wanted to ask if it is possible to fit only a certain field range of a CW EPR spectrum using esfit? For example, experimental range is [0 400] mT, but I just want to fit [300 350] mT. When I try to pass an incomplete range to esfit, some artifacts appear in the simulated spectra.
Is there any way to solve this problem? Remeasuring in a desired range is not an option for me.
Thank you!
joscha_nehrkorn
Re: esfit selected range
Post by joscha_nehrkorn »
The artifacts appear as the simulated spectra is broader than the chosen range.
This is independent of your measurement.
You might write your own fit function which simulates a larger range, like [0 400], but return only [300 350]. Take care that the number of points is identical for both experiment and fit.
