esfit constraint: multiple component with fixed ratio
gkwchow
Post by gkwchow »
Hi! I read the post to apply additional constraints when using esfit (viewtopic.php?f=3&t=142&hilit=constrain) for a single spin system and am adapting it to my system. Specifically, I have multiple nitroxides in a mixture (multiple systems) and am trying to pull out concentration changes over time. To that end, I introduce a dummy peak at g = 2.035, weight = 5 as an internal standard and derive relative concentrations by dividing the weight of individual components over that of this internal standard.
Since one of the components (SysX{4}) is tiny compared to others but has a signal at a very different field from the rest of the nitroxides, it can be simulated by only using a small portion of the spectra (call that weight x, SysX{4}.rat) and the internal standard. If not done this way, esfit would try to give it a non-zero concentration to help simulate other parts of the spectrum for some scans.
Then, I try to simulate the whole spectrum with other components. The internal standard is allowed to vary (ie the weight of it is now 5y) but I want to keep the weight of the tiny component to have constant ratio to the internal standard (ie xy).
I have written a custom function garlicX:
function [x,y] = garlicX(SysX,Exp,SimOpt)
%garlicX Component fixed proportion variation
%   Generates components on a fixed ratio
% SysX
SysX{4}.weight=SysX{4}.rat*SysX{5}.weight;
[x,y]=garlic(SysX,Exp,SimOpt);
If I simply call garlicX on an arbitrary system of 4 nitroxides (tiny component SysX{4}) and the dummy internal standard (SysX{5} and Sys_dum), it behaves like garlic while taking into account the ratio coefficient (SysX{4}.rat) and plotting it out.
However, when I tell esfit to call the following,
esfit('garlicX',epr_spc+5*transpose(garlic(Sys_dum,Exp)),Sys,VaryX,Exp);
I get this:
SysX =
         g: 2.0061
      Nucs: '14N,1H'
         A: [34.6404 32.9124]
      lwpp: [0.0384 0.0386]
    weight: 5
Cell contents reference from a non-cell array object.
Error in garlicX (line 5)
In other words, garlicX functions outside esfit, but when it is used in esfit, it only reads the 1st component. Currently, I am circumventing this by simulating all 5 components first and then the tiny component SysX{4}, but this would introduce (albeit small) error during the first step. My questions are
1. Is this due to how esfit works such that it made garlicX read only the 1st component in SysX?
2. Is there a better algorithm that can solve this problem?
Thanks!
Re: esfit constraint: multiple component with fixed ratio
It is possible that esfit does not correctly handle this case. However, I am not able to reproduce this (using ES 5.0.18).
Here is my code:
Exp.Range = [300 360];
Sys1.g = 2;
Sys1.lwpp = 1;
Sys2.g = 2.04;
Sys2.lwpp = 0.5;
SysX = {Sys1,Sys2};
[x,y] = garlicX(SysX,Exp);
Vary1.g = 0.01;
Vary2.g = 0.02;
VaryX = {Vary1,Vary2};
esfit('garlicX',y,SysX,VaryX,Exp);
and the custom function garlicX:
function [x,y] = garlicX(Sys,Exp,Opt)
if nargin<3, Opt = struct; end
[x,y] = garlic(Sys,Exp,Opt);
Does this work on your system? What are the minimal changes to this that reproduce your error?
