Radical pair
Abbey Philip
Radical pair
Post by Abbey Philip »
Dear all,
I'm trying to simulate the experimental EPR spectrum for a donor-acceptor radical pair (D.+ and A.-) system. I started with garlic for the simulation with the following matlab code
g1 = 2.012; g2 = 2.0023;
A1 = mt2mhz([16.9,10.9]/10); A2 = mt2mhz(9/10);
Sys.A = struct('S1',1/2,'Nucs','1H,1H','g',g1,'A',A1);
Sys.B = struct('S2',1/2,'Nucs','1H','g',g2,'A',A2);
Sys.tcorr = 1e-9;
Exp = struct('Range',[310, 340],'mwFreq',9.137,'lwpp',0.55,'npoints',64293);
garlic(Sys,Exp);
Is there anything fundamentally wrong with the code that it is giving me the error as:
Error in garlic (line 107)
Error in A (line 7)
garlic(Sys,Exp);
Please help.
Regards,
Abbey
Re: Radical pair
Well you have a couple problems with your inputs, fixing them up and you get:
SysA.S = 1/2;
SysA.g = 2.012;
SysA.Nucs = '1H,1H';
SysA.A = mt2mhz([16.9,10.9]/10);
SysA.lwpp = 0.55;
% or
% SysA = struct('S',1/2,'Nucs','1H,1H','g',2.012,'A',mt2mhz([16.9,10.9]/10),'lwpp',0.55);
SysB.S = 1/2;
SysB.g = 2.023;
SysB.Nucs = '1H';
SysB.n = 1;
SysB.A = mt2mhz(9/10);
SysB.lwpp = 0.55;
% SysB = struct('S',1/2,'Nucs','1H','g',2.023,'A',mt2mhz(9/10),'lwpp',0.55);
Exp.mwFreq = 9.137;
Exp.Range = [310 340];
Exp.nPoints = 64293;
% or
% Exp = struct('Range',[310, 340],'mwFreq',9.137,'nPoints',64293);
garlic({SysA SysB},Exp);
Now you'll probably notice I left out sys.tcorr, that is only important if you also provide anisotropy in g or A.
Are you trying to simulate a spin correlated radical pair? If you are, easyspin doesn't straightforwardly handle it, and garlic definitely doesn't do it. There are a few ways to simulate a SCRP with ES, though they involve using pepper, identifying the polarization of the transitions, and adding those transition together for the total spectrum. See http://easyspin.org/easyspin/documentat ... ation.html
Abbey Philip
Re: Radical pair
Thank you Dr. Matt for the prompt reply, it really helped me resolve the simulation error.
I'm new to EPR and am trying to simulate the radical pair formed on photoexcitation of donor-acceptor (D-A) system. However I'm not sure of a spin correlated radical pair in my D-A system as we aren't seeing any triplet present in the system from nanosecond data (is it necessary to see the triplet for SCRP mechanism?). Sir, how good is garlic while simulating the radical pair at 77K as compared to the chili?
Your reply was quite helpful and thanks once again for the prompt and fruitful solution to the simulation error.
Regards,
Abbey
