Shorku
Posts: 7 Joined: Tue Aug 11, 2015 9:20 am
Post
by Shorku » Tue Aug 11, 2015 9:31 am
I'm trying to import some ORCA calculation results, but keep getting
??? Attempted to access hfkeep(9); index out of bounds because
numel(hfkeep)=8.
Error in ==>
D:\work\easyspin-5.0.3\easyspin\orca2easyspin.p>orca2easyspin at 206
.prop is from orca 3.0.3, do not work both with doublets and triplets, command to import is for example
Sys = orca2easyspin('Cluster_g_N07D.prop');
am I doing something wrong?
Posts: 1150 Joined: Mon Jul 21, 2014 10:11 pm
Post
by Stefan Stoll » Tue Aug 11, 2015 5:12 pm
This looks like a bug. Please post your .prop file and your ORCA input.
Post
by Stefan Stoll » Tue Aug 11, 2015 9:09 pm
We just released ES 5.0.4. Try it with this version, the bug might be fixed.
Shorku
Post
by Shorku » Wed Aug 12, 2015 3:51 am
Thanks, 5.0.4 seems to work fine.
Small tip: it imports D tensor as is, in cm^-1, while for simulation it should be in MHz, no problems with conversion, but might be a bit confusing.
Post
by Stefan Stoll » Wed Aug 12, 2015 10:49 am
That's another bug. Thanks for reporting. You can download ES 5.0.5, where the bug is fixed.
Shorku
Post
by Shorku » Wed Aug 12, 2015 11:45 am
Thanks a lot, this new feature with importing calculation results is a great deal!
Shorku
Post
by Shorku » Tue Nov 10, 2015 7:31 am
I was trying to import results of calculation with several nuclei using orca2easyspin, but keep getting equal Aframe for all nuclei, that is not correct, is it a bug?
easyspin version 5.0.14
With best regards,
Oleg
Post
by Stefan Stoll » Tue Nov 10, 2015 8:36 am
Oleg, please post the ORCA input and output files and the associated .prop file so we can have a look what is going on.
Shorku
Post
by Shorku » Wed Nov 11, 2015 5:45 am
I made a simple test calculation with ORCA 3.0.3 and attached results. Import with orca2easyspin gives AFrame
-0,662542598650786 0,342303276412723 0,437403931852169
test.7z
(14.61 KiB) Downloaded 692 times
Post
by Stefan Stoll » Wed Nov 11, 2015 9:48 pm
This is indeed a bug, thanks for reporting! It is fixed in version 5.0.15, which just posted on the website.
