Hi All,
I am wondering if there is a function under EasySpin to directly calculate second moment (spectral breadth) from CW-EPR.
thanks
Indra Dev Sahu
Calculating second moment (spectral breadth) from CW EPR spe
Re: Calculating second moment (spectral breadth) from CW EPR
There is no dedicated EasySpin function for this. However, it should be possible to implement this in a few lines using the standard expression for the second moment.
Dear Dr. Stoll,
Thank you for the suggestion.
Indra
Indra
