esfit results and simulation
TKienz
Post by TKienz »
we are trying to use esfit to sumulate some rather complicated spectra of organic radicals. So far it works quite well, but when i use the the g-value, coupling constants and linebroadening provided by esfit and try simulate it, the simulation obtained does not look like the one esfit was showing as best result.
I have tried different methods, different scaling (scaling with baseline correction seem to work best, like lsq0). I have tried to use peak-to-peak linebroadening (lwpp) as well as FWHM (lw).
As far as I know the linebroadening is given in mT. I have tried if to convert them to Gauss, MHz and even tried if the value obtained is some sort of intrinsic value, where the starting parameter is set to 0 and the value retrieved is a fraction of +-1 of the range given.
Perhaps someone can help me with this issue.
g = 2,006600879
A1 = 10,67662615 G
A2 = 3,412601787 G
A3 = 3,411984069 G
A4 = 3,433421609 G
A5 = 3,432924588 G
lwpp = 0,232051906 mT
Seems like I can't attach the data converter get_MiniScope.m
Thank you all
EasyFitTestFcMeNOB.m
esfit file
(4.05 KiB) Downloaded 531 times
Fc.m
simulation File
(6.1 KiB) Downloaded 524 times
Fc_1_80_mg_3_2_mg_AgSbF6_1_3_mg_Nitroso_in_500_muL_CH2Cl2_RT_9419000.m
experimental data, change file extention to .spe
(8.06 KiB) Downloaded 525 times
TKienz
Re: esfit results and simulation
Post by TKienz »
Here the data converter get_Miniscope.m
get_MiniScope.m
data converter
(2.84 KiB) Downloaded 585 times
One think to check for is to make sure your Exp.Range settings are the same for the fitting and the simulations.
Can you trim down your code to a small snipped that demonstrates the problem, without the experimental data?
