Page 1 of 2
Amp in resfield
Posted: Wed Jul 08, 2015 8:42 am
by Hui18
Hi:
I am trying to use Amp produced by resfields function. May I know whether Amp is gamma times the square of matrix element or just the square of matrix element itself? For example, in the paper(
http://e-collection.library.ethz.ch/ese ... 411-02.pdf), is Amp calculated in the same way as Equation (2.50)?
Thank you very much in advance for your help!
Re: Amp in resfield
Posted: Tue Jul 14, 2015 10:40 pm
resfields
includes in the amplitudes (a) the square of the transition magnetic dipole moment, (b) the field-to-frequency conversion factor (which you call gamma), and (c) if a temperature is given, the population difference according to the Boltzmann distribution.
Re: Amp in resfield
Posted: Fri Nov 06, 2015 6:49 am
by hintze
Sorry for either hijacking or necrobumping this thread, but I would have chosen the same subject title for my question.
As far as I understand from your answer, @Stefan Stoll, the weighting factor of a given orientation is not taken into account in the amplitude output by resfields, is it? That means that if I would like to reconstruct the intensities from a spectral simulation, I also have to use the weights output by sphgrid. Or do I miss something here?
Re: Amp in resfield
Posted: Fri Nov 06, 2015 8:35 am
That is absolutely correct.
Re: Amp in resfield
Posted: Mon May 21, 2018 1:31 am
by thanasis
I am taking my turn to resurrect this question, as the thread is the most relevant: I would like to know how we can strip the resfield
calculation down only to the matrix element |<n|Sx|m>|^2, ignoring all other factors.
I would like to compare the transition probabilities calculated from ES with the ones analytically derived in different textbooks and papers for different exchange-coupled systems. For the arithmetic result to be directly comparable, should I take special care of the energy and field units?
There is also an undocumented Grad
field, which (when we set Opt.Verbosity to 2) is commented as gradient. Would that be the orientational gradient of a state energy?
Re: Amp in resfield
Posted: Mon May 21, 2018 12:50 pm
Here is a simple demo script on how to reproduce the transition rates calculated by
resfields
. Obvioulsy, if you tilt the magnetic field relative to the g-tensor frame, then things get a bit more tedious due to the Euler angles needed to handle the tilted orientations, but the physics is exactly the same.
clc, clear
Sys.g = [2 2.1 2.2];
Exp.Range = [300 400];
Exp.mwFreq = 9.5;
Exp.CrystalOrientation = [0 0 0];
Opt.Freq2Field = false;
[B,TransRate0] = resfields(Sys,Exp,Opt)
H = sham(Sys,[0 0 1]*B);
[V,E] = eig(H);
[Sx,Sy,Sz] = sop(Sys.S,'x','y','z');
u = V(:,1);
v = V(:,2);
c = bmagn*Sys.g(1)/planck/1e9;
TransRate1 = c^2 * (abs(u'*Sx*v)^2 + abs(u'*Sy*v)^2)/2
Re: Amp in resfield
Posted: Mon May 21, 2018 2:22 pm
by thanasis
Thanks Stefan!
I had been reading the
sop
documentation and couldn't figure out how to treat exchange-coupled systems. E.g., something like:
Sys.S = [5/2 5/2 5/2];
Gx = 0; Gy = 0; Gz = 0.2;
GG = [0 Gz -Gy; -Gz 0 Gx; Gy -Gx 0];
gz = 2;
gxy = 2;
Ja = -22.6;
Jb = -19.3;
Sys1.g = [gxy gz; gxy gz; gxy gz];
Sys1.ee = (100*clight/1e6)*[-2*Ja*eye(3) - 2*GG; -2*Ja*eye(3) + 2*GG; -2*Jb*eye(3) - 2*GG];
Indeed, when I used this sample script to make the calculation for my system,
sop
threw an error:
Error using sop
sop: Could not determine what 'x' is for the given spin system.
Error in sop
Is there a way to get around this?
Re: Amp in resfield
Posted: Mon May 21, 2018 9:12 pm
For calculating the transition moments and rates, you need the sum over spins:
[S1x,S1y,S1z] = sop(Sys.S,'x1','y1','z1');
[S2x,S2y,S2z] = sop(Sys.S,'x2','y2','z2');
[S3x,S3y,S3z] = sop(Sys.S,'x3','y3','z3');
Sx = S1x+S2x+S3x;
Sy = S1y+S2y+S3y;
Re: Amp in resfield
Posted: Tue May 22, 2018 12:49 am
by thanasis
Thanks for this Stefan,
I now made the calculations as you suggested, assuming:
Exp.Temperature = 4.2; Exp.mwFreq=9.801; Exp.CenterSweep=[350 700];
For the previously defined system, and for those experimental conditions, the results are:
<1|Sx|2> = <1|Sy|2> = 0.231365072811767
and since TransRate1 = c^2 * (<1|Sx|2> + <1|Sy|2>)/2 with c = bmagn*Sys.g(1)/planck/1e9 = 27.99249, I get Trans1Rate1 = 181.2929.
However the
resfields
result is TransRate0 = 10.1332 (with a very minor additional transition corresponding to transition 3-4). By removing the temperature from
Exp
resfields
calculates all possible resonances, and then indeed the 1-2 resonance is given with a TransRate0 = 181.2929 (and all others with non-realistic values for my experimental conditions). So I conclude that TransRate0 and TransRate1 coincide when we neglect thermal populations, right?
UPDATE: Subsequently, I calculated the Boltzmann populations of states 1 and 2 and multiplied with their difference:
pop = exp(-Ener*1e6*planck/boltzm/Exp.Temperature);
Intensity1 = TransRate1 * (pop(1) - pop(2))
which yields 20.206058, about double the result from
resfield
. I suppose I need to apply the 1/g Aasa-Vanngard correction. This gives practically the
resfields
result if g = 2.
Re: Amp in resfield
Posted: Tue May 22, 2018 9:28 am
You got it!
