Frequency Sweep
- Newbie
Frequency Sweep
How can I simulate a frequency sweep in EasySpin?
Re: Frequency Sweep
The current version 4.5.5 does not support frequency sweeps. The upcoming version 5.0 will fully support frequency sweeps. It will be released in the next few weeks, by the end of June.
Re: Frequency Sweep
I tried to do a frequency sweep where I set Exp.Range = [9.3 11] and as I change the magnetic field the spectrum zooms in the region where there is a resonance. For example at B=10 mT, it only shows the spectra between 9.5-9.8 GHz. How can I fix this problem?
Re: Frequency Sweep
Use Exp.mwRange = [9.3 11], not Exp.Range.
