Absolute weights in the absence of auto-scaling
I see that esfit() with EasySpin's built-in functions like garlic with the FitOpt.AutoScale = 'none' ignores defined Sys.weight and return it ad a weighted value at the range 0..1. My custom simulation functions work fine.
Re: Absolute weights in the absence of auto-scaling
Thanks. Can you please provide an example script that we use to troubleshoot?
Yes, of course. The spectrum is attached.
clear;
[x, y, par] = eprload('AnthTCNE_new\AntTCNE_DMCHA_lod_PBN_1day\AntTCNE_DMCHA_lod_PBN_1day_005.xml');
y=y';
Exp.Range=[min(x) max(x)];
x=10*x;
Exp.mwFreq=par.MwFreq;
Exp.nPoints=numel(x);
Sys.Nucs = '14N,1H';
Sys.n = [1 1];
Sys.A=mt2mhz([14.38 2.21]/10); %in G, 1mT=10G
Sys.g=2.00915;
Sys.lw=[0.06 0.025]; %Gauss Lorentz
Sys.weight=10;
Sys1.Nucs = '14N,14N,14N,1H';
Sys1.n = [1 1 1 1];
Sys1.A=mt2mhz([1.27 1.40 1.11 3.35]/10); %in G, 1mT=10G
Sys1.g=2.00574;
Sys1.lw=[0.048 0.065]; %Gauss Lorentz
Sys1.weight=10;
Opt.Method = 'exact';
FitOpt.AutoScale = 'none';
FitOpt.BaseLine = 2;
Vary.A=0.021*Sys.A;
Vary.g=0.001;
Vary.lw=0.995*Sys.lw;
Vary.weight=0.99999*Sys.weight;
Vary1.A=0.21*Sys.A;
Vary1.g=0.001;
Vary1.lw=0.995*Sys.lw;
Vary1.weight=0.99999*Sys1.weight;
%esfit(y,@garlic,{Sys,Exp,Opt},{Vary},FitOpt); %garlic iso, pepper aniso
esfit(y,@garlic,{{Sys,Sys1},Exp,Opt},{{Vary,Vary1}},FitOpt);
%esfit(y,@garlic,{Sys1,Exp,Opt},{Vary1},FitOpt);
AntTCNE_DMCHA_lod_PBN_1day_005.zip
(1.05 MiB) Downloaded 151 times
Thanks. This looks like a case where the initial values for Sys.weight are too far from the minimum. The simulated spectrum is about 410 times more intense than the experimental spectrum, so without autoscale initial values for Sys.weight need to be on the order of 0.05 or so to have a good chance that the optimization algorithm is able to find the minimum.
This works for me:
clc, clear
[B, spcexp, par] = eprload('AntTCNE_DMCHA_lod_PBN_1day_005.xml');
spcexp = spcexp.';
Exp.mwFreq = par.MwFreq;
Exp.Range = [min(B) max(B)];
Exp.nPoints = numel(B);
SysA.Nucs = '14N,1H';
SysA.n = [1 1];
SysA.A = [40.228 6.187];
SysA.g = 2.00901;
SysA.lw = [0.060 0.0279];
SysA.weight = 10;
SysB.Nucs = '14N,14N,14N,1H';
SysB.n = [1 1 1 1];
SysB.A = [3.639 3.980 3.062 9.273];
SysB.g = 2.00564;
SysB.lw = [0.0517 0.0694]; %Gauss Lorentz
SysB.weight = 10;
spcsim0 = garlic({SysA,SysB},Exp);
fprintf('Intensity of sim. spectrum: %e\n',max(spcsim0));
fprintf('Intensity of exp. spectrum: %e\n',max(spcexp));
% Set start values
SysA.weight = 0.05;
SysB.weight = 0.05;
varyA.A = 0.021*SysA.A;
varyA.g = 0.001;
varyA.lw = 0.995*SysA.lw;
varyA.weight = 0.99999999*SysA.weight;
varyB.A = 0.21*SysB.A;
varyB.g = 0.001;
varyB.lw = 0.995*SysB.lw;
varyB.weight = 0.99999999*SysB.weight;
esfit(spcexp,@garlic,{{SysA,SysB},Exp,Opt},{{varyA,varyB}},FitOpt);
