Hi all,
I am trying to reproduce a multi-trace EPR spectrum similar to the one attached (see image). The spectra contain three panels (A, B, C) with different spin states (S = 5/2 and S = 7/2) and different E/D values. I would like to know how to set up the simulation parameters and plotting commands in EasySpin to achieve similar results
Su
Reproducing spectral simulations
- fig1_ABC.png (106.67 KiB) Viewed 21213 times
Re: Reproducing spectral simulations
You have to use pepper
function with muliple component spectrum https://easyspin.org/easyspin/documenta ... icomponent
See also definition of zerofield splitting from D and E https://easyspin.org/easyspin/documenta ... tem.html#D
Thank you for your reply. I will take a careful look and give it a try.
