Hi.
I need a code for EasySpin version 6.0-alpha1,because I need to run the program about this document, the symm function in this code is misrecognized in any other version.
And I can't download the source code for EasySpin 6.0-alpha1 from GitHub.
Could you help me?
thank you very much!
EasySpin version 6.0-alpha1 source code
Re: EasySpin version 6.0-alpha1 source code
There is no 6.0-alpha1 tag on GitHub, and the symm
function has been renamed to hamsymm
in v6.0.0.
You can have a look at the history of hamsymm
to get the version you want: https://github.com/StollLab/EasySpin/co ... /hamsymm.m
Thank you very much for getting back to me, attached is the file I need to reproduce with the "symm" code in it, it needs 6.0-alpha1, by the way ,could the latest version 6.0.6 be used directly with the symm code?
- horseradish_github.m
- (12.46 KiB) Downloaded 1213 times
Replacing symm
with hamsymm
in this file should work.
