Dear Easy spin community,
I am writing a program to calculate the magnetic properties of a single crystal composed by several (interacting) metal complexes.
The metals are lanthanides, therefore (in C1 symmetry) a full set of 27 CF parameters must be used. I have a set of parameters expressed in the xyz magnetic reference frame (the reference frame in which the ground state g tensor is diagonal). I know the Euler angles connecting this frame and the crystallographic reference frame (the frame in which the magnetic field is expressed and in which I want my output).
The two magnetic reference frames of the coupled lanthanides are noncollinear. I set up the spin system using Sys.B2Frame (B4Frame, B6Frame), however the program only runs if the frame contains 3 Euler angles, not 6 (i.e. the program rotates the CF frame but the frames of the two spins are always collinear).
If I do the same with a simple ZFS Hamiltonian (Sys.Dframe) everything works and Sys.Dframe must be given with 6 Euler angles.
I attach hereafter some examples (here I use only B20 for simplicity). I have also tried to set up B2 with 5 elements instead of 1 (i.e. [0 0 x 0 0] vs x) and it does not work.
VERSION 1_ TWO NONCOLLINEAR LN IONS UNCOUPLED. PROGRAM DOES NOT RUN
Sys.S=[15/2 15/2];
Sys.g=[4/3; 4/3];
Sys.J=0clight1e-4;
Sys.B2=[-1/3;-1/3]clight1e-4;
Sys.B2Frame=[0 0 0; 90 90 0]pi/180; %%with Sys.B2Frame=[0 0 0, 0 0 0] the program does not complain but the simulation is not correct
Bvec=[0 0 1];
Ham=ham(Sys,Bvec1000);
ERROR MESSAGE:
Operands to the logical AND (&&) and OR (||) operators must be convertible to logical scalar values.
Use the ANY or ALL functions to reduce operands to logical scalar values.
Error in validatespinsys
Error in ham
Error in Freeenergytorque (line 139)
Ham=ham(Sys,Bvec*1000);
VERSION 2_ TWO (COLLINEAR) LN IONS UNCOUPLED. PROGRAM RUNS BUT THE INFO ABOUT 2ND REF FRAME IS LOST, WRONG RESULT
Sys.S=[15/2 15/2];
Sys.g=[4/3; 4/3];
Sys.J=0clight1e-4;
Sys.B2Frame=[0 0 0]pi/180;
Bvec=[0 0 1];
VERSION 3_TWO LN IONS COUPLED. PROGRAM WORKS AND THE SIMULATION IS CORRECT.
Sys.S=[15/2 15/2];
Sys.g=[4/3; 4/3];
Sys.J=0clight1e-4;
Sys.D=[-1;-1]clight1e-4;
Sys.DFrame=[0 0 0; 90 90 0]pi/180;
Bvec=[0 0 1];
