Issues with Levenberg/Marquart, garlic in Version 6.0.0
J_Barz
Post by J_Barz »
first a report of a small mistake in the manual: https://easyspin.org/easyspin/documenta ... tting.html states that for a hybrid fit, you call the arguments from the first stage via fit1.afit. Its fit1.argsfit{}{} where at least I find my data, afit is not created. That was easy to figure out.
But now I'm stuck, hybrid, non hybrid / single stage, when I carry out the following commands which I had been running for tons of spectra in 5.2.35:
Taken from 5.2.35:
FitOpt.TolFun = 1e-3;          % termination tolerance for error change
FitOpt.TolStep = 1e-4;         % termination tolerance for parameter step, Levenberg/Marquardt
FitOpt.TolEdgeLength = 1e-3;   % termination tolerance for parameter step, simplex
FitOpt.nIter = 500;
FitOpt.maxTime = 3;     % maximum time, in minutes
FitOpt.maxGenerations = 40; % Generations
FitOpt.AutoScale = 'none';
FitOpt.Method = 'levmar int';
Updated for 6.0.0:
fit2 = esfit(spcs,@garlic,{DMPO_SYS(2,:), Exp}, {DMPO_VARY}, FitOpt);
It gives me as a reply:
-- esfit ------------------------------------------------
Number of datasets: 1
Data set 1: 3999 points
Model function name: garlic
Number of fit parameters: 5
Minimization algorithm: Levenberg-Marquardt
Residuals computed from: integral
Autoscaling: none
Running optimization algorithm with 5 active parameters...
iteration 1: value 7.00478e+04 gradient 3.28912e+11 step 4.41756e-03
Terminated: Parameter step below threshold of 0.0001
Calculating parameter uncertainties...
Estimating Jacobian...
** Spectrum exceeds sweep range. Artifacts at lower limit possible.
Calculating parameter covariance matrix...
Calculating parameter correlation matrix...
Parameters:
name value standard deviation 95% confidence interval
1 arg1{1}.g 2.006100 7.963657e-05 ( 0.004 %) 2.005944 - 2.006256
2 arg1{1}.A(1,1) 41.75718 0.3530521 ( 0.845 %) 41.06521 - 42.44915
3 arg1{1}.A(1,2) 41.64452 0.5221534 ( 1.254 %) 40.62112 - 42.66792
4 arg1{1}.lw 0.5000000 0.01965603 ( 3.931 %) 0.4614749 - 0.5385251
5 arg1{1}.weight 1.000000 0.03569025 ( 3.569 %) 0.9300484 - 1.069952
Correlation matrix:
1.000000 -0.754405 -0.063909 0.000356 -0.001203
-0.754405 1.000000 0.048562 0.003965 -0.001474
-0.063909 0.048562 1.000000 0.006611 -0.000486
0.000356 0.003965 0.006611 1.000000 -0.165580
-0.001203 -0.001474 -0.000486 -0.165580 1.000000
Strongest correlations:
p(1)-p(2): -0.754405
p(4)-p(5): -0.16558
p(1)-p(3): -0.0639089
p(2)-p(3): 0.0485616
p(3)-p(4): 0.0066107
Goodness of fit:
ssr 229038
rmsd 7.56794
noise std 7.56889 (estimated from residuals; assumes excellent fit)
noise der 0.000206445 (estimated using der_snr algorithm)
red chi-square 1.34383e+09 (using noise der estimate)
Error using garlic
No broadening given. Cannot compute spectrum with Exp.Harmonic=1.
Error in compisoloop
Error in garlic
It is not working with genetic either. I call genetic as
FitOpt.Method = 'genetic fcn';
Same issue. It's actually only DMPO-OH being fitted, spectrum fully contained in the spectral range, had all been working in 5.2.35. Any ideas on what I'm doing wrong? In general, garlic doesn't seem to read the current linewidth from the fit result in my case.
Re: Issues with Levenberg/Marquart, garlic in Version 6.0.0
Thanks for reporting the error in the fitting userguide!
Regarding the issue with garlic and esfit, please post your spin system variable DMPO_SYS and DMPO_VARY.
MMSIM
Post by MMSIM »
similar problem:
used in previous version:
SimOpt.Method = 'exact';
esfit('garlic',spc,{Sys2},{Vary2},Exp,SimOpt,FitOpt);
is not working now: errror sign:
Error in DMPOOH_spektrum_simulacia (line 77)
any reccomendation how to fix it? thanks
DanielKlose
Post by DanielKlose »
Hello MMSIM,
your call to esfit corresponds to EasySpin version 5.x.
In the new version EasySpin 6.x this has been updated to include more flexibility.
Please see the documentation of esfit or the post above, you'll see a different arrangement of the arguments.
Best wishes!
