effective spin-system and pseudonuclear effects with saffron
Re: effective spin-system and pseudonuclear effects with saf
You can work around this by using Opt.Transitions = [1 2]. This will tell saffron to only use the transition between levels 1 and 2 (the lowest Kramers doublet) and skip all the other transitions.
In order for this to work properly, please download the latest version 5.0.16, which just posted.
lorenz
Post by lorenz »
Thank you very much!!!
I'll try it. Thats perfect.
tastich
Post by tastich »
Wouldn't explicitly stating the temperature also work? Although the calculation would take longer.
In the current version, there is no way of specifying the temperature.
However, there is a workaround: Use Opt.Transitions to specify the transitions between the electron manifolds you want to be included in the ESEEM simulation. In your case: Opt.Transitions = [1 2].
