I'm studying the angular variation of a spectrum (solid state, cw EPR) and I'm not interesting by the shape of spectra, only their value of the magnetic field at resonance (in order to limit the number of points for an external use).
Is there a simple way (already computed in EasySpin) to obtain this value ?
Thank you for your help !
effective value of g at resonance
- EasySpin Guru
Re: effective value of g at resonance
Perhaps try using resfields. You'll need to specify your spin system and several experimental parameters.
Okay, I'm going to try this.
Thank you !
Thank you !
It's exactly what I was lookin' for ! Thank you again !
