Custom fitting methods for esfit
Can I use custom fitting methods for esfit()? Primarily interested in methods from MATLAB's Global Optimisation Toolbox. It seems similar to using the lsqnolin function from a similar Optimisation Toolbox.
This seems to require only minor changes to the esfit() source code, am I right?
Re: Custom fitting methods for esfit
This is currently not possible. All the optimization algorithms are hard-wired into esfit, and most of them are EasySpin implementations.
But there might be a workaround hack: Take your custom optimization function, wrap it with a function called lsqnonlin, make sure it has the same input syntax as lsqnonlin from the Optimization Toolbox, and use it with Opt.Method = 'lsqnonlin'.
Thanks. I see, esfit() calls lsqnonlin() at the form
[pfit_active,~,~,~,output] = lsqnonlin(residualfun,p0_active,lb_active,ub_active);
So, the outpust of the 'fake' lsqnonlin() should be the same, am I right?
Yes, if you replicate the input and output syntax of lsqnonlin, then esfit should be able to call it without issues.
