alternative compiler specification, linux
The gcc version is 4.1.2 and 4.4.7 is available only as gcc44. How can I tell easyspin to use gcc44 instead of gcc? I don't have administrator access for the linux machine and switching to a the newer version as gcc is not allowed. Thanks. - Will
Re: alternative compiler specification, linux
What message do you get when you run
Also, go to the easyspin/private subfolder in the ES installation folder and run
Try running
easyspincompile
?Also, go to the easyspin/private subfolder in the ES installation folder and run
mex -v cubicsolve.c
. What do you get?Try running
mex -v CC=gcc44 cubicsolve.c
. Does that work?Re: alternative compiler specification, linux
Sorry, it looks like -lstdc++ is missing? Thanks. -Will
>> easyspincompile
EasySpin compilation
directory: /home/xuser/easyspin-4.5.0/easyspin/private
version: 7.14.0.739 (R2012a)
mex extension: mexglx, 32-bit
compiling...
Warning: You are using gcc version "4.1.2". The version
currently supported with MEX is "4.4.6".
For a list of currently supported compilers see:
http://www.mathworks.com/support/compil ... t_release/
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
mex: link of ' "chili_lm0.mexglx"' failed.
Error using mex (line 206)
Unable to complete successfully.
Error in /home/xuser/easyspin-4.5.0/easyspin/easyspincompile.p>easyspincompile
(line 41)
>> mex -v cubicsolve.c
Warning: Neither -compatibleArrayDims nor -largeArrayDims is selected.
Using -compatibleArrayDims. In the future, MATLAB will require
the use of -largeArrayDims and remove the -compatibleArrayDims
option. For more information, see:
http://www.mathworks.com/help/techdoc/m ... nue-1.html
-> mexopts.sh sourced from directory (DIR = $MATLAB/bin)
FILE = /usr/local/MATLAB/R2012a/bin/mexopts.sh
-> MATLAB = /usr/local/MATLAB/R2012a
-> CC = gcc
-> CC flags:
CFLAGS = -ansi -D_GNU_SOURCE -fPIC -pthread -m32 -fexceptions -D_FILE_OFFSET_BITS=64
CDEBUGFLAGS = -g
COPTIMFLAGS = -O -DNDEBUG
CLIBS = -Wl,-rpath-link,/usr/local/MATLAB/R2012a/bin/glnx86 -L/usr/local/MATLAB/R2012a/bin/glnx86 -lmx -lmex -lmat -lm -lstdc++
arguments = -DMX_COMPAT_32
-> CXX = g++
-> CXX flags:
CXXFLAGS = -ansi -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -fPIC -pthread
CXXDEBUGFLAGS = -g
CXXOPTIMFLAGS = -O -DNDEBUG
CXXLIBS = -Wl,-rpath-link,/usr/local/MATLAB/R2012a/bin/glnx86 -L/usr/local/MATLAB/R2012a/bin/glnx86 -lmx -lmex -lmat -lm
-> FC = gfortran
-> FC flags:
FFLAGS = -fexceptions -fbackslash -fPIC
FDEBUGFLAGS = -g
FOPTIMFLAGS = -O
FLIBS = -Wl,-rpath-link,/usr/local/MATLAB/R2012a/bin/glnx86 -L/usr/local/MATLAB/R2012a/bin/glnx86 -lmx -lmex -lmat -lm
-> LD = gcc
-> Link flags:
LDFLAGS = -pthread -shared -m32 -Wl,--version-script,/usr/local/MATLAB/R2012a/extern/lib/glnx86/mexFunction.map -Wl,--no-undefined
LDDEBUGFLAGS = -g
LDOPTIMFLAGS = -O
LDEXTENSION = .mexglx
arguments =
-> LDCXX =
-> Link flags:
LDCXXFLAGS =
LDCXXDEBUGFLAGS =
LDCXXOPTIMFLAGS =
LDCXXEXTENSION =
arguments =
-> gcc -c -I/usr/local/MATLAB/R2012a/extern/include -I/usr/local/MATLAB/R2012a/simulink/include -DMATLAB_MEX_FILE -ansi -D_GNU_SOURCE -fPIC -pthread -m32 -fexceptions -D_FILE_OFFSET_BITS=64 -DMX_COMPAT_32 -O -DNDEBUG "cubicsolve.c"
-> gcc -O -pthread -shared -m32 -Wl,--version-script,/usr/local/MATLAB/R2012a/extern/lib/glnx86/mexFunction.map -Wl,--no-undefined -o "cubicsolve.mexglx" cubicsolve.o -Wl,-rpath-link,/usr/local/MATLAB/R2012a/bin/glnx86 -L/usr/local/MATLAB/R2012a/bin/glnx86 -lmx -lmex -lmat -lm -lstdc++
mex: link of ' "cubicsolve.mexglx"' failed.
-> CC = gcc44
-> CC flags:
CDEBUGFLAGS = -g
-> CXX = g++
-> CXX flags:
CXXDEBUGFLAGS = -g
-> FC = gfortran
-> FC flags:
FDEBUGFLAGS = -g
FOPTIMFLAGS = -O
-> LD = gcc44
-> Link flags:
LDDEBUGFLAGS = -g
LDOPTIMFLAGS = -O
arguments =
-> LDCXX =
-> Link flags:
LDCXXFLAGS =
LDCXXDEBUGFLAGS =
LDCXXOPTIMFLAGS =
LDCXXEXTENSION =
arguments =
-> gcc44 -c -I/usr/local/MATLAB/R2012a/extern/include -I/usr/local/MATLAB/R2012a/simulink/include -DMATLAB_MEX_FILE -ansi -D_GNU_SOURCE -fPIC -pthread -m32 -fexceptions -D_FILE_OFFSET_BITS=64 -DMX_COMPAT_32 -O -DNDEBUG "cubicsolve.c"
-> gcc44 -O -pthread -shared -m32 -Wl,--version-script,/usr/local/MATLAB/R2012a/extern/lib/glnx86/mexFunction.map -Wl,--no-undefined -o "cubicsolve.mexglx" cubicsolve.o -Wl,-rpath-link,/usr/local/MATLAB/R2012a/bin/glnx86 -L/usr/local/MATLAB/R2012a/bin/glnx86 -lmx -lmex -lmat -lm -lstdc++
>> easyspincompile
compiling...
(line 41)
>> mex -v cubicsolve.c
-> CC = gcc
-> CC flags:
CDEBUGFLAGS = -g
-> CXX = g++
-> CXX flags:
CXXDEBUGFLAGS = -g
-> FC = gfortran
-> FC flags:
FDEBUGFLAGS = -g
FOPTIMFLAGS = -O
-> LD = gcc
-> Link flags:
LDDEBUGFLAGS = -g
LDOPTIMFLAGS = -O
arguments =
-> LDCXX =
-> Link flags:
LDCXXFLAGS =
LDCXXDEBUGFLAGS =
LDCXXOPTIMFLAGS =
LDCXXEXTENSION =
arguments =
-> CC = gcc44
-> CC flags:
CDEBUGFLAGS = -g
-> CXX = g++
-> CXX flags:
CXXDEBUGFLAGS = -g
-> FC = gfortran
-> FC flags:
FDEBUGFLAGS = -g
FOPTIMFLAGS = -O
-> LD = gcc44
-> Link flags:
LDDEBUGFLAGS = -g
LDOPTIMFLAGS = -O
arguments =
-> LDCXX =
-> Link flags:
LDCXXFLAGS =
LDCXXDEBUGFLAGS =
LDCXXOPTIMFLAGS =
LDCXXEXTENSION =
arguments =
It seems Matlab/mex cannot find the standard C++ library on your computer. It expects it in /usr/local/MATLAB/R2012a/bin/glnx86 (See CLIBS in your output). If you can locate libstdc++.* on your computer (maybe in a subfolder of /usr/local/MATLAB/R2012a/sys/os), then you can create a symbolic link from bin/glnx86 folder to that place, and Matlab/mex should be able to find it.
