In the ES documentation (http://easyspin.org/easyspin/documentat ... em.html#ee), Sys.J is defined as a 1xN array.
For 2-e systems, antisymmetric and dipolar interactions are entered into separate structures (Sys.dvec and Sys.eeD, respectively) as Nx3 arrays. This apparently causes no problems.
However, for 3 electrons and above, they have to be entered into the Sys.J structure. The problem is that Nx3 arrays need to be added (?) into a 1xN array.
Maybe I am missing something, but I believe it would be useful for the documentation to be more explicit regarding the coexistence of the symmetric, antisymmetric and dipolar parts within Sys.J for 3 electrons and above.
Thanks for considering!
Sys.J with Sys.dvec & Sys.eeD for more than two electrons
Re: Sys.J with Sys.dvec & Sys.eeD for more than two electron
This is a typo in the documentation. For 3 and more electrons, the same syntax should work as for 2 electrons. I.e., you should be able to use
J
, dvec
, and eeD
.Re: Sys.J with Sys.dvec & Sys.eeD for more than two electron
Thanks Stefan, this clears it up.
Also another point: does
I.e. for a triangle:
Do we instruct:
or
dvec
know to inverse the sign so that Si x Sj = -Sj x Si
?I.e. for a triangle:
Sys.S = [1/2 1/2 1/2];
Sys.J = [J12 J13 J23];
Sys.dvec = [d12; d13; d23];
or
Sys.dvec = [d12; -d13; d23];
No, it doesn't do anything with the sign. The rows in
Internally, EasySpin converts
Sys.dvec
correspond to d12, d13, d14, d23, d24, d34, etc., and never d21, d31, d41, d32, etc.Internally, EasySpin converts
Sys.J
, Sys.dvec
, and Sys.eeD
to Sys.ee
, and then uses only the latter for simulations. Here is the code:Code: Select all
idx = 1:3;
for iPair = 1:nPairs
J = Sys.J(iPair);
d = Sys.dvec(iPair,:);
ee = J*eye(3) + ...
[0 d(3) -d(2); -d(3) 0 d(1); d(2) -d(1) 0] + ...
diag(Sys.eeD(iPair,:));
Sys.ee(idx,:) = ee;
idx = idx + 3;
