UIControl Callback
Ntasha
UIControl Callback
Post by Ntasha »
I keep on getting UIControl Callback error when I try to fit my EPR. What does that mean?
Re: UIControl Callback
There are a lot of reasons throwing such error. Please give full output of Matlab.
Ntasha
Post by Ntasha »
Here is the full output
Error using magint
g tensor must be symmetric for this method.
Error in chili
Error in chili
Error in esfit
Error in esfit_simplex
Error in esfit
I am trying to fit the diffusion angles (and the rates of rotation) of a spin labeled lipid inside a bilayer (powder spectra).
Here is my system setup
Nx =
g: [2.0086 2.0058 2.0020]
Nucs: '14N'
A: [13.7000 13.7000 96.4000]
logDiff: [7.2500 8.8500]
DiffFrame: [6.2832 0.1745 0]
I am assuming that the spin label can rotate around its long axis freely (360degrees) and then wobble in the cone imposed by its environment. Some angles give me the error. I am not sure why.
Ntasha
Post by Ntasha »
Attached is the example of the fitting I get
Screen Shot 2017-10-26 at 10.19.21 AM.png (321.8 KiB) Viewed 3351 times
Please give the script and exp data which causes the eror. Or alternatively try to run fitting with Opt.Verbosity=2. It gives much more information.
Also make sure to test this with the latest version of EasySpin (see the website). If you are using an older version, it might be that this is a bug that was already fixed.
