Dear all,
I just realized that pepper is issuing an error message whenever the dipolar component of the interaction matrix, given as Sys.eeD, is not axial. The error however refers to non-zero trace, which is not the case (see below).
V_MA119t11.eeD=[-3.1e-3 1.6e-3 1.5e-3]*29979
Error using pepper
Sys.eeD contains dipolar tensors with non-zero trace. Use Sys.J for this
One can easily circumvent this by providing the full matrix via Sys.ee, of course.
Regards,
LS
minor issue using Sys.eeD
Re: minor issue using Sys.eeD
This is be design.
If you want to specify the principal values of the full coupling tensor (isotropic + symmetric), you can use
Sys.J
(isotropic exchange), Sys.eeD
(symmetric) and Sys.dvec
(antisymmetric) are intended to be used together, so Sys.eeD
should be traceless.If you want to specify the principal values of the full coupling tensor (isotropic + symmetric), you can use
Sys.ee
. See here.Re: minor issue using Sys.eeD
Dear Stefan,
thanks. My point was however a different one: in the example I included Sys.eeD is indeed traceless (-3.1 1.6 1.5), but this produces an error message anyhow. It looks like Sys.eeD has to be in the form [1 1 -2]*const or any permutation of it, i.e. axially symmetric, for the error message not to be issued. Of course, this is not a major problem, since one can always resort to Sys.ee and the full coupling tensor.
I cannot reproduce this problem. This minimal example works fine on my machine:
It could be an issue of numerical noise, in which case
Sys.S = [1/2 1/2];
Sys.g = [2 2.03];
Sys.eeD = [-30 10 20];
Exp.mwFreq = 9.5;
pepper(Sys,Exp);
Sys.eeD = Sys.eeD - mean(Sys.eeD)
can help.-
This should be fixed now in version 5.1.11.
