Error in EPR load
natalia
Error in EPR load
Post by natalia »
I recently installed Matlab R2015b. When I tried to load a bruker file the following message came up.
I am not sure what bufSize is. Can anyone help please?
>> [B59d,spc59d] = eprload('kk759d_wide');
Error using textscan
'BufSize' is no longer required and has been
removed.
Error in eprload
Error in eprload
Error in eprload
Re: Error in EPR load
Check whether you have the latest version of EasySpin. This used to be a bug, but was fixed in 5.0.8.
natalia
Post by natalia »
That was it!
Thank you. :D
myersw802
Post by myersw802 »
I have Matlab 2015b and EasySpin 5.0.22, error for multiple files of Xenon and Xepr origin is:
'BufSize' is no longer required and has been removed.
Error in eprload
Error in eprload
Error in plot_ENDORxy (line 10)
[b,a,par] = eprload('AUTOSAVE0000.DTA');
This started spontaneously after some weeks/months with the Matlab EasySpin combo above. I'm using a pre-textscan eprload for now.
This should not appear anymore in 5.0.22 with R2015b. Here is the corresponding code from eprload:
MatlabVersion = sscanf(version,'%f',1);
if MatlabVersion<8.6  % prior to R2015b
    warning('off','MATLAB:textscan:BufSizeDeprecation');
    allLines = textscan(fh,'%s','whitespace','','delimiter','\n','bufsize',500000); %#ok<BUFSIZE>
  else
    allLines = textscan(fh,'%s','whitespace','','delimiter','\n');
Please post a file so we can test this (again).
myersw802
Post by myersw802 »
>> version
ans =
8.6.0.267246 (R2015b)
>> easyspininfo
Release: 5.0.22 (2016-05-17)
Expiry date: 30-Jun-2017
Folder: [ ... ]
MATLAB version: 8.6.0.267246 (R2015b)
Platform: Microsoft Windows [Version 6.1.7601]
mex-files: mexw64, ok
System date: 16-Jul-2016 21:39:01
Temp dir: [ ... ]
Please post DTA and DSC files that generate this error, so we can look into it.
myersw802
Post by myersw802 »
Sorry I missed the following error messages that appeared previously. The file attachment appears like it might work this time.
The extension dsc is not allowed. The extension des is not allowed. The extension txt is not allowed.
AUTOSAVE0000.m
rename extension to DSC
(2.9 KiB) Downloaded 1077 times
The extension dta is not allowed. The extension dat is not allowed.
AUTOSAVE0000.p
rename the extension to DTA
(23.44 KiB) Downloaded 1113 times
Thanks. I cannot reproduce this problem. The file loads cleanly with R2015b and 5.0.22 on my Win10 computer. Can you check whether the correct functions are being called? Use
which eprload -all
which textscan -all
myersw802
Post by myersw802 »
That's it! Sorry I thought I had checked that previously by paring the path down to just EasySpin, but apparently not. Many thanks. -Will
...\Documents\MATLAB\UserCommunity\BrittLab\eprload.p
