Fitting multiple variables for CW-EPR using new unstable version
fawce047
Post by fawce047 »
I have been able to get fits for one component systems using the chili function via the code below in the unstable form of Easyspin.
esfit(spc, @chili, {Nx1,Exp}, {Vary1})
However, the data that I need to fit is a two-component system. Modifying the line above to get a two-component system in a similar way shown in the examples leads code below
esfit(spc,@chili,{Nx1 Exp Nx2 Exp},{Vary1 Vary2});
leads to an error stating that "Parameter 8: Field .weight is missing in input 2."
Is there something that I am inputting wrong in the unstable version of Easyspin? Any help would be appreciated.
Re: Fitting multiple variables for CW-EPR using new unstable version
You have use esfit(spc,@chili,{{Nx1,Nx2}, Exp},{{Vary1,Vary2}});
