fitting two spectra with esfit
Patto
Post by Patto »
I've been trying to fit two spectra for one sample at different frequencies using X band and Q band. I tried previous posts (viewtopic.php?p=1743&hilit=globalfit#p1743 viewtopic.php?p=3166&hilit=scale#p3166). ButI always run into the error "First input parameter must be a valid function name or function handle." Does anybody share me an example to do this. THX
xq.m
(1.72 KiB) Downloaded 662 times
EricWalter
Re: fitting two spectra with esfit
Post by EricWalter »
What version of Matlab are you using? I had problems with functions defined inside a script with older versions (I just made the function a separate .m file). But beyond that, it looks like you will overwrite your x-band data with your Q-band, I think you need to cat them together. And I think you need to scale each simulation to the experimental data separately.
I got your script to run in version 6 with matlab 2018 by replacing line 53 with the new syntax for esfit:
esfit(spc,@mysimfun,{Sys,Exp,SimOpt},{Vary},FitOpt);
So you could try downloading the development version and pasting that line in.
Patto
Post by Patto »
EricWalter wrote: Mon Mar 06, 2023 12:21 pm
I do this using matlab 2020b and easyspin 5.2.33. I tried matlab 2021a and easyspin 6, it works. But I don't konw how to cat two spectra together? For easyspin 6, how do I get the fitted spectra and values?
Patto
Post by Patto »
I've met a problem that two spectra shares different line width. How do define different line width for two spectra? THANK YOU!
EricWalter
Change the lw value in the function when you get to each, the same as you do the Exp values (you will have to Vary each separately):
Sys0.lw =Sys.lwX;
yX = pepper(Sys0, Exp, SimOpt);
Sys0.lw =Sys.lwQ;
yQ = pepper(Sys0, Exp, SimOpt);
