Nuc isotope ratio error
EricWalter
Post by EricWalter »
I'm try to simulate hyscore with Ba and Sn, and it keeps giving me an error when I try to give it isotopes, so I went to the "spin system" section of the documentation and cut out the example:
Sys.Nucs = '63Cu,(32,33)S'; % 63Cu with enriched 33S
Sys.Abund = {1,[0.1,0.9]]; % 100% 63Cu, 10% 32S and 90% 33S
And even it gives the same error as my script:
Error using nucdata
Problem in isotopes list, entry 3 ('33)S'): Please specify one of 32S, 33S, 34S, 36S.
Error in validatespinsys
Error in saffron
What is the correct syntax? Maybe it has changed for version 6.
Williamnbell
Re: Nuc isotope ratio error
Post by Williamnbell »
Helpful! Thanks for providing these tips.
saffron does currently not support isotope mixtures. If you have such a situation, call saffron separately for each isotopolgue combination. The function isotopologues should be useful for this.
