Fitting SQUID data
dar_06
Fitting SQUID data
Post by dar_06 »
Dear All,
As we got some SQUID data we need to understand, I tried a number of software to try to fit them. EasySpin seems sensible, and I thought I would go through it easily as I already use it for EPR. However, I run into some problems which I don't really understand. Basically our system is a metal centre antiferromagnetically coupled with a ligand radical. So I am trying to extract J and g.
My code is below
% SQUID measurement
clear, clf, clc;
%Defining the J in Easyspin Format
cm=2.99793e4
% Defining experimental parameters
path = '\path\to\SQUID\data\'
cd(path);
Exp.Field = 500;
[T,chi] = textread('exp_data.txt', '%f %f') % reads data in txt format
%Defining the spin systems
J = -22;
g = 2;
Sys.S=[1/2 1/2];
Sys.g=[g g];
Sys.ee=-2*cm*[J J] % MHz
%Sys1.D = [30 30] % cm-1
% then vary the g and J accordingly
Vary1.g = [0.5 0.5];
Vary1.ee = 2*cm;
FitOpt.OutArg = [1 1]; %to fit the magnetic susceptibility chizz
FitOpt.nKnotts = 31;
FitOpt.Scaling = 'none';
%Call esfit
Exp.Temperature = T;
Exp.Field = 500;
esfit('curry', chi,Sys,Vary1,FitOpt);
Regardless of where I put Exp.Temperature = T or Exp.Temperature= 2:300 in the script, it does not seem to pass it to curry. I get the error
Exp.Field is missing, assuming zero field.
Error using curry
Exp.Temperature is missing.
Error in esfit
Error in esfit_simplex
Error in esfit
The txt data are attached.
I am using easyspin-5.2.35. I also tried to used the easyspin-6 version, but there I got into a lot of other types of errors which made me revert.
Any help would be appreciated.
Best wishes,
Adrian
exp_data.zip
(676 Bytes) Downloaded 671 times
Re: Fitting SQUID data
It looks like you forgot to pass Exp into esfit.
Also, if you are just including isotropic exchange coupling, Sys.ee should only be a single value.
dar_06
Post by dar_06 »
Excellent, many thanks, Matt. I had it in originally but removed it as I kept switching between versions 5 and 6. It makes sense why I had the error.
However, now I have a different error
Error using esfit
Field S is given in Vary, but not in Sys0. Remove from Vary or add to Sys0.
But as you see from the code, field S is defined as Sys.S and not in Vary, where I have only Vary1.g and Vary1.ee. I have no Sys0 defined. Would you have any tips on this? Maybe it is again trivial, but I am just learning this and hence I may miss obvious things.
