Unrecognized field name "q".
radzikovitsky
Post by radzikovitsky »
I am using easyspin (v6.0.0-dev.38) with orca5 to compute epr spectra of paramagnetic diruthenium complexes.
I am trying this:
Sys = orca2easyspin('filename.out');
Sys.lwpp = 1;
Exp.Temperature = 500;
Exp.Range = [315 350];
pepper(Sys, Exp)
with orca5 input below:
! HF def2-svp d3bj cpcm(water)
*xyzfile 0 2 xyz_file.xyz
%eprnmr
	gtensor 1
	Nuclei = all Ru {aiso, adip, aorb, fgrad, rho}
While it works perfectly with the example calculation from manual, when I try doing this to my output files, I get
Error in validatespinsys
Error in pepper
Error in pepper.
How ths problem could be solved?
Re: Unrecognized field name "q".
This looks like a bug. Can you please post your ORCA5 output file? Then we can try to reproduce the bug and fix it.
