"High-order zfs parameter" at esfit?
seradır
Post by seradır »
Hi
I want to fit my spectra by using esfit to get crystal field parameter. I prefer to use "High-order zfs" parameters (B20,B22,B21,B40,..) instead of zfs parameters (D,E).
How can modify? Maybe, Can it be done with using "user-defined simulation function" ?
ES codes:
clear all; clc;
Data_Exp=load('Data','-ascii');
B=Data_Exp(:,1);
spc=Data_Exp(:,2);
S=5/2; %[5/2; 5/2];
g=2.02 ;
lw=10; FieldRange=[0 700];
Freq=9.18;
talfa=3; tbeta=40; tgama=0;
Center1=[talfa tbeta tgama]*pi/180; % tilt angles in Euler System for paramagnetic center 1 Center2=[talfa+90 tbeta+0 tgama+0]*pi/180; % tilt angles in Euler System for paramagnetic center 2 %========================Define Parameters================================% Sys1=struct('S',S,'g',g,'lw',lw); Sys2=struct('S',S,'g',g,'lw',lw); Sys1.B2=[3000 400 5000 0 0];
Sys2.B2=[3000 400 5000 0 0]; Exp=struct('Range',FieldRange,'mwFreq',Freq); Exp.CrystalSymmetry='C2h';
Exp.CrystalOrientation = [0 0 0]*pi/180;
Exp.MolFrame=[Center1; Center2]; %================================================ SimOpt.Output='separate';
SimOpt.Method='matrix'; %--------------------------------------------------------------------------------- FitOpt.Method='levmar'; FitOpt.Scaling ='lsq2'; %--------------------------------------------------------------------------------- Sys1.MolFrame=Center1; % ??? Sys2.MolFrame=Center1; % ??? %Sys1.CrystalOrientation = [0 0 0]*pi/180; % ??? %Sys2.CrystalOrientation = [0 0 0]*pi/180; % ??? %Vary1.CrystalOrientation=[20 120 0]; % ??? %Vary2.CrystalOrientation=[20 120 0]; % ??? %--------------------------------------------------------------------------------- esfit('pepper',spc,{Sys1,Sys2},{Vary1,Vary2},Exp,SimOpt,FitOpt)
Re: "High-order zfs parameter" at esfit?
That's not necessary. All you need to do is to provide
Vary.B2 = [0 0 50 0 0];
etc. Then the fitting program will use and vary the B2 parameters.
However, it might be easier to just fit using Sys.D and then convert the fitted D and E values to the various B2 parameters.
seradır
Post by seradır »
Great! Thank you very much.
Sometimes, we need to adjust CrystalOrientation euler angles because of misalignment (1-3 degrees) in experiment procedure. Can we change these angles at esfit?
Yes, you can do this using a user-defined simulation function.
