eprload
pihua498
eprload
Post by pihua498 »
I'm watching video from the EasySpin Academy session 1 and try to learn by repeating.
Firstly easyspin found a new version easyspin-6.0.0-dev.28 and this got installed.
Then I deleated the folder easyspin-6.0.0-dev.26 and set path the new version.
In the Editor window, I type
1 clear
2 clc
3
4 [B,spc] = eprload('radical.DTA');
5 plot(B,spc);
In the command window:
Error using eprload
The file or directory radical.DTA does not exist!
Error in Untitled (line 4)
How do I do now?
Thank for an answer
Re: eprload
radical.DTA and radical.DSC were example experimental files used in the workshop, and they are not part of EasySpin. Instead of these, you can use your own spectral datafiles.
