Greetings,
I started trying to fit a set of magnetization curves with curry and esfit.
If I use Opt.Scaling = 'none', I get an error when starting the fitting in interactive mode:
Unrecognized function or variable 'scalefactor'.
Error in rescale
Error in esfit
Error in esfit_simplex
Error in esfit
But if I don't include that option it works fine, although then the fitting parameters would not make sense, because the g value dependence is on the maximum values of the magnetization. This also happens if I just change to No scaling in the interactive esfit window.
Is this a bug?
I have version 5.2.28
Best wishes,
Nicolas
