Nuclear spin forbidden transitions
taylorrl3
Post by taylorrl3 »
Hi All,
I am currently trying to simulate a Mn(II) species, however I am unable to simulate the "forbidden doublets" between the 6 main transitions. These arise from Ms=+/-1, Mi=+/-1 forbidden transitions. When I use levelsplot, it appears as though only electron spin forbidden transitions are calculated, and doesn't calculate any nuclear spin forbidden transitions.
Would anyone be able to advise me how to include these in my simulation?
Thanks in advance!
nwili
Re: Nuclear spin forbidden transitions
Post by nwili »
Please post a minimal example of your script. What parameters do you use?
joscha_nehrkorn
Post by joscha_nehrkorn »
Levelsplot uses a threshold for plotting. This means all transitions are calculated, but only those with a transition probability above the threshold are displayed. However, if you want to see more (or all) transitions you can adjust that threshold. In the below example all possible transitions are drawn.
Sys = struct('S', 5/2, 'Nucs', '55Mn', 'A', 250 , 'D', 500);
par.PlotThreshold = 0;
levelsplot(Sys,'x', 400, 9.6, par)
You might want to look at
[p,i,w,t] = resfields(Sys,Exp);
