Not getting hyperfine from orca2easyspin
Posted: Thu Sep 13, 2018 4:52 pm
Hello!
I'm very new to MatLab, I'm messing around with Easyspin because I want to use the program for research purposes. I've run an Orca calculation for hexa-aquo Manganese [2+] with epr output (see input file attached).
I checked the output file to make sure that hyperfine values were calculated for the atoms I specified (and I specified atoms that were unnecessary in addition to the Mn atom just to see what Orca would spit out), and yet when I run the orca2easyspin for the .prop file (posted below because the file type was not allowed):
The line in orca that I specified post-xyz information was:
%eprnmr
gtensor 1
Nuclei = all H {aiso, adip, aorb, fgrad, rho}
Nuclei = all O {aiso, adip, aorb, fgrad, rho}
Nuclei = all Mn {aiso, adip, aorb, fgrad, rho}
DTensor ssandso
DSOC cp # qro, pk, cvw
DSS uno # direct
When I attempted to import the resulting .prop file, I received the following:
Sys =
struct with fields:
S: 2.5000
xyz: [19×3 double]
Charge: 2
g: [2.0029 2.0031 2.0039]
gFrame: [0.7865 0.2444 -2.8809]
Nucs: []
And when I then added Nucs via Sys.Nucs = '', specified line widths, etc, and attempted to run saffron, I got:
Error using saffron
No hyperfine tensors A given for the 1 electron spins and 1 nuclei in
the system!
Error in saffron
After looking at this forum for a few minutes, it seems obvious that orca2easyspin is not importing the hyperfine information that I know is in the output file. Any assistance would be greatly appreciated.
Best
%eprnmr
gtensor 1
DTensor ssandso
DSS uno # direct
Sys =
struct with fields:
S: 2.5000
xyz: [19×3 double]
Charge: 2
Nucs: []
Error using saffron
the system!
Error in saffron
Best
